XT-1 Manual focus problem, 35mm 1.4 lens
Discussion in 'X-T2, X-T1, X-T20, X-T10, X-T100' started by Tazdog, Oct 12, 2017.
  1. Tazdog
    Tazdog New Member
    May 10, 2015
    25
    Virginia
    I have the manual focus button enabled. When I focus manually it should zoom into what I am focusing on correct? Why would that not be working? I also have AF-L button set to switch, should it not stay focused when I enable it until I press the AF-L switch again to disengage it? Is there something in the menu that I do not have set right.
  2. Goldingd
    895
    216
    Firmware version. History at: Please login or register to view links
    Latest at : Please login or register to view links
    And just in case, for your X-T1 : Please login or register to view links
    morhafren likes this.
  3. Tazdog
    Tazdog New Member
    May 10, 2015
    25
    Virginia
    Yep!! I did the body and not the lens!
  4. Tazdog
    Tazdog New Member
    May 10, 2015
    25
    Virginia
    I have updated the lens firm ware. The body was already up to date. Still have the same problem????
  5. Goldingd
    895
    216
    Not sure on your model. Manual Focus Assist On? Does a menu option exist on or off in the setup menu.
  6. Goldingd
    895
    216
    In the New Features Guide, consider page EN-4
