Xraw studio problem on Windows PC
Discussion in 'Post Processing Forum' started by rmmacalalad, Jul 10, 2018.
  1. rmmacalalad
    rmmacalalad Well-Known Member
    Jun 22, 2018
    50
    138
    Singapore
    Hi All, I tried to install x raw studio on my windows PC few times already. My camera has been detected by the software, i can see all the raw pictures however, i cannot manage to convert It into a Jpeg file and all the adjustment bars are grey out.
    Does anyone experience this issue?
  2. Arjay
    13,608
    5,378
    I cannot reproduce your problem - but are you sure you aren't trying to process RAW files that are located on your camera's SD card?
    They need to be on your computer's hard disk, from where you can select and send them to your camera for processing.
  3. rmmacalalad
    Jun 22, 2018
    50
    138
    Singapore
    Yes all Raw format. And it is located on my SD card that is inserted on the camera. Then i connect the camera via cable to PC
  4. Arjay
    13,608
    5,378
    You first have to save your files to your PC, then you can select them from your HDD to be processed in X Raw Studio. The software will then send the file to your camera for processing, and retrieves the resulting JPG files back to your PC.
  5. YogiMik
    YogiMik Premium Member
    Sep 27, 2014
    3,368
    3,086
    Norway
    You need to transfer those RAW files to the PC first, then selected one X Raw Studio sends to the camera for processing.
  6. rmmacalalad
    Jun 22, 2018
    50
    138
    Singapore
    Thank you ill try later [emoji4]
