X100S Firmware question
Discussion in 'X100F, X100T, X100S, X100, and X70' started by Booger, Aug 12, 2017.
  1. Booger
    Booger New Member
    Aug 29, 2014
    Atlanta
    I've owned, and loved, an X100S since they were introduced and had no negative issues whatsoever. I've done none of the firmware updates thinking, if it isn't broke don't fix it. Thoughts?
    Thanks in advance,
    Booger
  2. Oldtimer
    Oldtimer Premium Member
    Jul 30, 2017
    134
    51
    1st thought
    I would update the firmware.
    2nd thought
    I wouldn't update the firmware.
    3rd thought
    ...and continue
    What do you want to do?
  3. Beaumont
    Beaumont Premium Member
    May 29, 2015
    374
    148
    ladysmith B.C.
    What good reason is there not to update?
  4. Dennisr
    Dennisr New Member
    Sep 12, 2013
    York. England
    Hi Booger
    Just do it and you will find the updates are worthwhile. The boffins at Fujifilm know what they are doing.
    Kind regards
    Dennisr
  5. Arjay
    13,336
    5,076
    Fuji firmware updates don't just contain bug fixes, but also functional improvements (and Fuji often didn't describe these improvments in their release notes).
    If you don't have a problem, then this is because you haven't used any of the camera's functions that needed improvements. So you feel you don't need an update (don't fix it if it ain't broke...).
    However, you forget about the improvements - most (not all) are documented in Fuji's update history. What's more important however is when the last update was released, and if problems with that update were reported in the forum. I'm not aware that Fuji left any loose ends open with its last X100s firmware update.
    FYI:
    In a nutshell: I would run the update; it's not going to ruin the camera, or else we'd have heard of it.
  6. Oldtimer
    Jul 30, 2017
    134
    51
    I would second Arjay's comments. I've never had a problem with any firmware upgrade from Fuji, only benefits and functional improvements have resulted.
    Apologies for my earlier flippant post. However, in the end it's really up to you. I'm sure it doesn't need a forum to convince you.
