X-T20 Quickmenu
Discussion in 'X-T2, X-T1, X-T20, X-T10' started by aw-landscapes, Apr 12, 2018.
  1. aw-landscapes
    aw-landscapes New Member
    Mar 25, 2018
    I've been browsing through the menu countless times...
    Is there really no way to add images stabilisation and AF+MF to the Quickmenu?
    If not, is there a place where Fuji gather feedback?
  2. Richard_R
    7,754
    7,978
    I don't understand.
    None of the cameras in this forum section have IBIS so the only way to have stabilisation is IF the lens fitted has it and IF the physical lens switch is in the on position.
    Likewise MF and AF are controlled by a physical switch on the camera body.
  3. aw-landscapes
    Mar 25, 2018
    Thanks for the reply.
    I have an XC lens which doesn't have the IS switch so I have to activate or deactivate IS in the camera. Sometimes I switch a lot between handheld and tripod and it sucks a bit to have to enter the menu every time to do that.
    For the second part I mean the AF + MF option with which you can activate the focus control zoom with the focus ring after using AF. I'd like to be able to toggle on/off via the Quickmenu, but I guess it's not possible.
  4. Bizarro
    Bizarro New Member
    Apr 10, 2018
    Quite a few Fuji lenses don't have switches. The AF+MF function is just that a function, it isn't AF or MF.
  5. sandroamt
    sandroamt Premium Member
    Jan 8, 2016
    148
    51
    Italy
    On x-t10 (I think it is similar on x-t20) In shooting mode
    - press and hold the quick button "Q" ;
    - select the position you want to change and press "menu/ok" button
    - select the function you like and press "menu/ok" button
    Anyway, on x-t10 you can find the "Image stabilization" function but NOT the "AF+MF" one, only the "AF-mode" (single, zone, wide track). Maybe on x-t20 fuji improved that?
  6. aw-landscapes
    Mar 25, 2018
    Thank you, I had been there. Unfortunately on the T20 IS
  7. aw-landscapes
    Mar 25, 2018
    Just noticed that my last reply wasn't complete. Unfortunately IS is not avaible for the Quickmenu anymore. Maybe now with the new update...
  8. bbawt
    bbawt Member
    Mar 30, 2018
    I didn't see IS in the list of options when customizing Quickmenu after the firmware update. I assigned it under My Menu as next best solution.
