X-T2 vs X-T3
Discussion in 'X-T3, X-T2, X-T1, X-T20, X-T10, X-T100' started by LionSpeed, Sep 7, 2018.
  1. M4cr0s
    M4cr0s Premium Member
    May 23, 2011
    457
    185
    I'm in the same boat. Had planned to preorder the T3 for at least a year. And I did. Then came a promotion with 50% off of the grip. Cancel. Re-preorder :p Going for silver. My only fear is the slightly lower contrast on the dials vs white on black.
    Lumens likes this.
  2. pixelstate
    pixelstate Premium Member
    Oct 11, 2014
    236
    370
    United Kingdom
    I went to try out the X-T3 the other day... like the fool I am I forgot to take my RRS base plate for a fit-test! Doh...
    From a visual inspection and from on-line research I think that plates should fit but the grip will not (due in part to pin location changes)
    Please login or register to view links... seems like a super-charged X-T2
  3. pixelstate
    Oct 11, 2014
    236
    370
    United Kingdom
    I never had much of a problem with the diopter on the X-T2 and was concerned about the 'watch crown' action of the new diopter on the X-T3 but having used it it seems to be well designed... easy to grip and adjust and felt solid.
  4. Macro
    Macro Premium Member
    May 2, 2014
    760
    231
    Will you be going back soon? ;)
    Many X-T2 users are wondering if they'll need to spend another $180 for a new plate.
  5. Lumens
    Lumens Premium Member
    May 25, 2015
    285
    196
    Mesa, AZ
    That's the impression I had gotten from the reviews, left me hesitating on my purchase quite a bit. Most improvements appear to be in video which I don't do - the rest is better sensor/faster(better) AF - Good, but still nothing new that I cannot already do with my XT-2.
    I have been thinking about a second camera so with the "Chinese" price I can't resist. I have been using the XT-1 as a backup, but with all the firmware improvements on the XT-2 the XT-1 is a backup ONLY - to be used if desperate - definitely not a second camera. The "VALUE" of the XT-3 just puts the competition to shame - it will be nice to have a second camera to carry a second lens.
  6. Lumens
    May 25, 2015
    285
    196
    Mesa, AZ
    For my XT-2 I bought a cheap plate off Amazon for about $40. It has served me extremely well for the price - as good if not better than the $180 brand. I'll do the same for the XT-3 if the XT-2 plate does not fit.
    AnthonyM likes this.
  7. Greybeard Photography
    Apr 23, 2017
    442
    124
    The MHG-XT2 grip is a thing of beauty and very functional - but £119 for a piece of metal - from online pictures the shape has definitely changed so I'm not hopeful.
  8. Macro
    May 2, 2014
    760
    231
    While clamped in an Arca clamp in portrait orientation, most L-brackets do not provide adequate clearance to attach a cable to the left-side ports. Either the open port door flap hits the clamp, or the attached cable hits the clamp.
    RRS did solve that problem with the X-T2.
    Work-arounds with the X-T3 may be easier as the port door is removable and the remote port is now located on the upper right side above the card slots. The remaining left-side ports may still be compromised while clamped in an L-Bracket in portrait orientation.
  9. Lumens
    May 25, 2015
    285
    196
    Mesa, AZ
    I must've gotten lucky as my cheapy worked fine - I am able to connect the left side ports, but then I won't say it is easy.
  10. digitalpatriot
    digitalpatriot New Member
    Feb 9, 2018
    XT2 w/ grip owner here. I pre-ordered the XT3 in silver w/ grip. So excited. Thanks for these comparisons. I really hope it's delivered to my house on September 21. I haven't seen any word on when they'll actually ship or if they have enough units to ship.
    Selling my 10/10 XT2, estimated 13k clicks on it, for 900. Posting it up on the bay once my T3 arrives!
  11. fzdp
    fzdp Premium Member
    Aug 30, 2017
    169
    124
    European Union
    You just have to buy a cheap plate but with TWO screws. If you do not mind estethics it is easy to make it work with the left side ports for about 1€ for longer screws. It works for remote cable release from Canon.
  12. LionSpeed
    LionSpeed Premium Member
    Jan 22, 2016
    837
    1,133
    SoCal
    Just a few more days until the arrival of my T3-Argentum.
    .... waiting a tat impatiently!
    LS.
    fugu 82-2 likes this.
  13. Ish
    Ish Premium Member
    Feb 5, 2013
    2,522
    579
    Northamptonshire, UK
    I think this may be because the eyepiece looks as though it comes out further at the back. The minimum depth of the camera is the same
    X-T2
    132.5mm (W) x 91.8mm (H) x 49.2mm (D) (minimum depth 35.4mm)
    X-T3
    132.5mm (W) x 92.8mm (H) x 58.8mm (D) (minimum depth 35.4mm)
  14. LionSpeed
    Jan 22, 2016
    837
    1,133
    SoCal
    I guess most of you already know this. Grip from T2 won't work with T3 due to different location of the pins. :(
  15. Greybeard Photography
    Apr 23, 2017
    442
    124
    Yes - had heard that - still nothing definitive on the other grip - Fuji MHG-XT2 grip
  16. roalk
    roalk Premium Member
    Apr 27, 2013
    671
    342
    Queensland, Australia
    The key here seems to be the use of the pins to locate the grip. Can anyone who owns the MHG-XT2 clarify if it uses the locating pins?
    I own the MHG for the X-T1 and there are no pins on that model so if the MHG-XT2 doesn't use the pins there's a good chance it will fit the X-T3 as well.
  17. Greybeard Photography
    Apr 23, 2017
    442
    124
    No pins - I'm more concerned with the change in the camera grip shape
  18. LionSpeed
    Jan 22, 2016
    837
    1,133
    SoCal
    My T3-Argentum has been updated from "back order" to "processing" this morning.
    Let's go! :)
    Ish likes this.
  19. Ish
    Ish Premium Member
    Feb 5, 2013
    2,522
    579
    Yay! Looking forward to hearing all about it :)
  20. MickM
    MickM Member
    Dec 9, 2017
    Can anyone tell me if the function buttons on the X-T3 are the same size as those on the X-T2? Also, do they stand out more from the body than on the older model? Perhaps the only criticism of my X-T2 is that I find the function buttons a little small and would prefer not to attach Sugru to make them more tactile. Many thanks.
