X-T2 Firmware 4.10 Released! (June 13)
Discussion in 'X-T2, X-T1, X-T20, X-T10' started by BillC-PA, Jun 13, 2018.
  1. BillC-PA
    BillC-PA Premium Member
    Sep 7, 2013
    1,072
    553
    North of Philadelphia - Bern Township
    Firmware update 4.10
    kevinlamphoto likes this.
  2. ToneXA1
    ToneXA1 Premium Member
    Aug 4, 2014
    205
    98
    Ljubljana, Slovenia
    Better?
  3. Benjamin Kanarek
    Benjamin Kanarek Premium Member
    Oct 8, 2017
    127
    179
    Born in Toronto, Canada based in Paris, France
    I am getting a "FIRMWARE NOT FOUND IN CARD SLOT 1. TURN OFF CAMERA. message.
  4. Mike Gorman
    Mike Gorman Premium Member
    Mar 4, 2017
    1,186
    739
    West London
    Make sure you have accurately loaded the update to the top directory of the SD card, it must read exactly FWUP0010.DAT and nothing else.
  5. ToneXA1
    Aug 4, 2014
    205
    98
    Ljubljana, Slovenia
    Just to duly check out the basics:
    - download the latest FW from fujifilm.com support site to your comp (FW has to be newer than the one in the camera, i.e. of higher ver. No.)
    - copy the file FWUP0010.DAT on a SD card
    - once duly copied, insert the SD (on which you have only the file FWUP0010.DAT) in slot 1 of the camera
    - turn the camera on while holding the disp/back button pressed
    Camera recognises the FW but still makes you select the upgrade of the body (not of the lens). The rest should be easy...
    Good luck.
  6. Benjamin Kanarek
    Oct 8, 2017
    127
    179
    Thanks guys..I inadvertently downloaded 2 and it added a (1) copy suffix
  7. AnthonyM
    AnthonyM Premium Member
    Mar 26, 2014
    1,496
    728
    London, UK
    Been there, done that!
  8. Benjamin Kanarek
    Oct 8, 2017
    127
    179
  9. Mike Gorman
    Mar 4, 2017
    1,186
    739
    West London
    There ya go, next time I’ll bet you check! :)
  10. Benjamin Kanarek
    Oct 8, 2017
    127
    179
    Indeed I will! Thanks :)
    Mike Gorman likes this.
  11. lysander
    lysander If at 1st you don’t succeed, lower your standards.
    Sep 6, 2014
    523
    172
    FL, USA
    The firmware for the X-T2 will always be: FWUP0010.DAT
    BillC-PA likes this.
  12. Photoron
    Photoron Premium Member
    Mar 8, 2013
    199
    Long Island, NY
    Ecactly, and to avoid confusion it is really best to delete older versions of the firmware, since you can NOT go back to a previous version they really have no further use.
  13. MARTIN DIGGS
    MARTIN DIGGS New Member
    Jun 15, 2018
    Mine says I have uploaded the firmware successfully... even when I recheck the installed version, it says 4.01, however, I do not have any of the functionality of said update. IE no, 120 fps at 1080, focus bracketing, etc.
    How do I fix that... I have tried loading reinstalling the firmware twice now, same result.
  14. MARTIN DIGGS
    Jun 15, 2018
    sorry... 4.10
  15. Woodlink
    Woodlink Premium Member
    Dec 20, 2014
    523
    271
    Birmingham, Alabama
    Ok,
    So I have installed 4.10 and for the life of me, I don't see the SELECT FOLDER option.
    Other added functions like Flicker Reduction are there, but for the life of me I cannot find the SELCET FOLDER option.
    Anyone having the same issue?
  16. cheddar-caveman
    cheddar-caveman Premium Member
    May 22, 2017
    351
    198
    Devon, England
    When doing an update, Fuji recommend that:
    !/. Have a fully charged battery
    2/. Format the SD card from slot 1 in the camera.
    3/. Transfer the .DAT file onto it from your computer
    4/. Replace the card in the camera
    5/. Turn on the camera while pressing the DISP/BACK button.
  17. cheddar-caveman
    May 22, 2017
    351
    198
    Devon, England
    I seem to remember that when 4.0 was first released there was a link to an addendum for the manual explaining the new functions, but I can't find it.
    Can someone point me in the right direction please as I want to play with the "FOCUS BRACKETING".
    I understand the "steps", 2-999 - how many pictures you want to take but what are the "STEP" and "INTERVAL" please? If the "INTERVAL" is in seconds, how can one hand hold the camera as I have seen pictures of someone who did?
  18. defjoe
    defjoe Member
    Sep 7, 2017
    Check out this YouTube video. It’s all very well explained here.
  19. cheddar-caveman
    May 22, 2017
    351
    198
    Devon, England
    I gather one needs Photoshop or similar to be able to process" the images after capture. I only have a fairly old Photoshop Lightroom 5 which I got free when I bought a Canon quite a few years ago. Hope it can cope with this, can't afford a new version :(
