X-T1 rear wheel
Discussion in 'X-T2, X-T1, X-T20, X-T10' started by Fran Velasco, Feb 13, 2018.
  1. Fran Velasco
    Fran Velasco New Member
    Mar 16, 2017
    Madrid
    Hi everyone,
    I've been using the X-T1 for more than a year and I'm wondering now if there is something you can use with the rear wheel. I know you can change aperture on XC lenses, but on lenses with aperture ring, is there any possible use for that dial?
    I'm pretty sure I've never used it with my 2.8/14, 1.4/23 or 2/50 mounted. It would be awesome if you could change ISO or something, anything.
  2. Dirk Offringa
    1,231
    805
    exposure shift (shifting exposure while maintaining EV value, meaning you shift for instance the SS by 1/3 stop down and the Aperture 1/3 stop up) is the default assignment in shooting mode. Browsing though images otherwise. Or browsing through the menus and changing values. I don't see the use of having ISO there as we have already a dedicated dial for this.
    Fran Velasco likes this.
  3. Fran Velasco
    Mar 16, 2017
    Madrid
    Thanks dirk, but to use it as an exposure shifter I must have ISO, aperture ring and SS in Auto. Otherwise it's still useless.
    And yes, I use it to browse and other menu operations, I forgot! I was asking only for shooting mode. Maybe I should have posted this on other board, I'm no newbie at all haha, but I still see that wheel useless while shooting with my kit.
  4. merosen
    merosen Premium Member
    May 20, 2014
    247
    119
    Somerville, MA
    If you shoot with maual shutter speeds, set the shutter speed to "T".
    You cand use the comand dial to scroll thru the shutter speeds.
    If yo have the command dial set up to be reversed than the the front dial will change speeds
    Easier than switching the dial on top.
    This is on an X-t1, dont know how it is on other cameras
    CSG and Fran Velasco like this.
  5. Doug Pardee
    Doug Pardee Premium Member
    Aug 27, 2016
    107
    65
    When focus-assist is activated, the rear command dial can be used to switch between the two zoom levels.
    To make a very picky correction: the rear command dial is Program Shift when you're in P mode. So yes, you need to have lens and shutter speed set at A to use that. However, Program Shift works with both fixed ISO and auto-ISO. It does not work if DR-Auto is selected. Program Shift also doesn't work with lenses that use the rear command dial for aperture control.
    Knut and Fran Velasco like this.
  6. merosen
    May 20, 2014
    247
    119
    Somerville, MA
    If you use a lens with no aperture control, the rear dial is shutter speed, front dial is aperture control.
  7. Dirk Offringa
    1,231
    805
    to spice things up a bit:
    -only when focus is set to manual
    -only in when focus assist is in standard mode
    -not when in double screen mode in the viewfinder
  8. jamie allan
    jamie allan Premium Member
    Aug 2, 2014
    1,781
    2,635
    Glasgow Scotland Europe
    I think you mean the other way round - the normal setting is that the rear dial is aperture control whereas the front will allow restricted shutter speed change ie if the shutter dial on top of the camera is set to 1/125 then rotating the front dial will allow you to go from 1/80 to 1/160.
  9. merosen
    May 20, 2014
    247
    119
    Somerville, MA
    I changed it around a couple of times, so I couldn't remeber the default
    If You want the aperture on the front, go to the menu that reverses the comand dial function
    Yes, you can set a speed on the top and it will give you room to change it within a few stops
    But as I wrote, putting it on "T" lets you go the whole gamut of shutter speeds
    Fran Velasco and Dirk Offringa like this.
  10. Fran Velasco
    Mar 16, 2017
    Madrid
    Thank you everyone.
    I used to work as a photographer, so not planning of using auto aperture or auto shutter speed in the near future. No way I'm letting the camera decide for me except for the ISO. So I guess the rear wheel will last more than the camera because for me it will keep unused.
    Robmas4229 and Dirk Offringa like this.
  11. rsn48
    rsn48 Active Member
    Feb 8, 2018
    64
    25
    Its clear everyone is using a different X T1 than the other guys.
    mokeiyong likes this.
  12. merosen
    May 20, 2014
    247
    119
    Somerville, MA
    You can configure the command dial to have the aperture work on the back, Speed on front or change around in the menu to be the other way around.
    I prefer the aperture dial on the front for lenses without apeture rings, it in a nearby place, so all I have to do is move my hand a bit from when I'm using a lens with a ring, Just the way i shoot. Aperture is always on the front.
    In same way you can configure the focus ring to be clockwise or counter clockwise in the menu system
    So, every one has a different X-t1 than everbody else. Customization
