X-E3 RAW files NOT SUPPORTED in Capture One 10.2.1
Discussion in 'Post Processing Forum' started by Firmin, Nov 13, 2017.
  1. Firmin
    Firmin New Member
    Nov 13, 2017
    Hello, i just bought a XE3 camera from Fuji. It seems to be a nice sensor, but unfortunately I cannot develop my RAW files in Capture One. I am really disappointed and I don't want to change this great software wich i use every days.
    Does anybody have any idea when the EX3 fils will be supported in C1 ?
  2. Aureliano Buendia
    Aureliano Buendia Well-Known Member
    Jun 17, 2015
    99
    347
    venus
    Next update?
    In the meantime you can change the exif of the pictures, modifying x-E3 in X-T20.
    I make so and it works
  3. Firmin
    Firmin New Member
    Nov 13, 2017
    Ok. Thx.
    What do you mean by "changing the exit of the picture" ?
    I don't even see my .RAF files in my import window in C1.
  4. Arjay
    13,605
    5,375
    EXIF data are image metadata that are embedded in the RAW and JPG image files. If you use an EXIF editor, you can change the camera designation in these data sets to e.g. X-T20, and then many image editors that "don't yet know" the X-E3 will recognize the files as if they originated from an X-T20. This is possible because both cameras not only share the same resolution, but also the same sensor and processor.
    Flostfisher likes this.
  5. Firmin
    Firmin New Member
    Nov 13, 2017
    Ok great ! I was looking for an… EXIT
    And wich EXIF editor allow this on MAC ? I am used to C1 as editor…
    Anyway, I'll look for one doing .RAF
    That's really stupid that C1 is not able to recognize these images witch are the same as any Fuji-X
    Thanks a lot !
  6. Richard_R
    8,370
    9,208
    Have you sent an email to Capture One asking that question? The manufacturer of a product usually has a better understanding of release timetable than end users do.
  7. Firmin
    Firmin New Member
    Nov 13, 2017
    Actually, the EXIF editor seems to be a pretty good way… I'll try.
    I did send an email to C1 and they wrote me back 10 minutes after :
    Dear Sir/Madam,
    As a general principle, we do not comment on future product development.
    Specifically, for Capture One development and camera support, our ambition is to support all top selling high end camera models. We evaluate each camera request we receive as a unique case and Capture One now supports more than 400 different cameras from Canon, Sony, Nikon, Fuji, Olympus, Pentax and naturally Phase One just to mention a few. All cameras are individually optimized by a special/unique Phase One technology process.
    Kind regards,
    Phase One Support
  8. jptsr1
    jptsr1 Premium Member
    Nov 8, 2017
    140
    66
    New Jersey
    Sooooooooo.........2 weeks?
  9. Firmin
    Firmin New Member
    Nov 13, 2017
    They won't give any precise timing.
    It was an automatic response i guess, posted by an automatic employee…
    So i went back and asked agin : I need an answer !
    And, so, a real employee wrote :
    Unfortunately I do not have information on when or if we will support this camera. I have put this is n as a feature request on your behalf.
    Very secret company indeed…
    However, the EXIF editor works fine.
  10. jptsr1
    Nov 8, 2017
    140
    66
    New Jersey
    Which editor are you using? Does it do batches or do you have to edit each one individually?
  11. Firmin
    Firmin New Member
    Nov 13, 2017
    I looked a lot… and the only one i found, which seemed to be reliable (and it is) is : EXIF EDITOR
    A small app i bought on the apple store (11€… not so cheap).
    It works fine with batches, although, i only tried with 10 pictures.
    But it seems fine and complete.
    My main concern now, is that this Fuji Lens : 23mm 1:2, has a lot of chromatic aberration (green franges mostly) and C1 doesn't deal with Fuji Lens…
    So the CA option in C1 is not effective, it's even worse sometimes.
    Affordable camera, good sensor, but post prod is complicated.
    If anybody have any trick concerning these CA, i am interested.
  12. FS670ES
    FS670ES New Member
    Dec 1, 2017
    Check Silkypix. As far as I remember you have those corrections there. You can set all things, then export to DNG and then edit DNG in Capture One. Another way is using Irridient Developer.
  13. Arjay
    13,605
    5,375
    Doesn't C1 also feature a manual CA correction tool? Correcting CA manually, e.g. in LR isn't hard at all.
  14. zdys
    zdys New Member
    Jan 14, 2018
    You can use exiftool (Please login or register to view links). Install, change to the picture directory and enter in CLI:
    exiftool -overwrite_original -Model="X-T2" *.raf
    After that you can use the raw files in capture one pro 10.*
    Thanks for the idea from this forum, found exif command line on dpreview thread, wanted to share. Given procedure has been tested and works on OSX 10.12.6
  15. janda
    janda Member
    Apr 23, 2012
    21
    Chichester UK
    Yesterday’s update 11.01 includes X-E3 file handling.
