X-E2S shows Body Version 4.0
Discussion in 'X-E1, X-E2, X-E2S, X-E3' started by VintageJim, Sep 13, 2018.
  1. VintageJim
    VintageJim Well-Known Member
    Sep 13, 2018
    25
    54
    Michigan
    I am the second owner of a X-E2S. I just tried to update the firmware to v1.11. I fresh-formatted a SD card, downloaded the firmware on my MacBook Pro, copied the firmware to the SD card, properly ejected the card from the computer, put the card into the X-E2S, switched on the camera holding the DISP/BACK button, said to upgrade body firmware, camera said no firmware on card. I verified the 1.11 firmware was indeed on the card.
    Further investigation shows that the Body Version says 4.0. Can I assume the former owner upgraded the camera with x-E2 firmware? Is it possible some early X-E2S were shipped with X-E2 firmware? Should I try to update to X-E2 4.11 firmware?
    Hoping someone here has input or been down a similar path.
  2. robert
    16,054
    5,561
    Are you sure it's an X-E2S?
  3. tijuana taxi
    tijuana taxi Premium Member
    Oct 3, 2015
    1,016
    772
    Cambridgeshire, UK
    I suppose someone of dubious character could use the case of a X-E2s and the innards of an E2.
  4. robert
    16,054
    5,561
    See if it updates to 4.11.
    Where did you get this camera?
  5. VintageJim
    Sep 13, 2018
    25
    54
    Michigan
    Yes. 100% . I had hoped I put in enough detail in my post, but here's this...
  6. VintageJim
    Sep 13, 2018
    25
    54
    Michigan
    Private individual. She purchased from Adorama this past December. I have all the boxes, manuals, etc. I am 100% certain this is an X-E2s.
  7. VintageJim
    Sep 13, 2018
    25
    54
    Michigan
    Also, is there any appreciable difference between 4.11 for the X-E2 and 1.10 for the X-E2S?
  8. fujixacros
    fujixacros Premium Member
    Jan 8, 2017
    708
    245
    Fr
    Hello,
    1 -Do you have the initial invoice of this camera body that mentions the type and the name of the body ?
    2 - Would it be possible to change the top cover with the name of the body ?
    3 - What do the EXIFs say about your photos?
    Ps: really the same dimensions.
  9. VintageJim
    Sep 13, 2018
    25
    54
    Michigan
    Ahhhh... Peeking at the EXIF, it says it's an X-E2.
    BUT... I have all the original packing and manuals. The serial number on the camera matches the box.
    Occam's razor taken into account, she "upgraded the firmware with the X-E2 firmware. My guess is the camera recognized v4.0 as greater than v1.0 and allowed the "upgrade."
  10. Goldingd
    968
    287
    So, try this, import an image into your computer, and look at the metadata, what camera is listed?
  11. SixstringSlinger
    SixstringSlinger Active Member
    May 17, 2018
    91
    42
    SoCal, USA
    Hmm, I recently upgraded the firmware in my new X-t100. I got the same "no firmware error" when I fired up the camera. I found that I miss-clicked when I went to copy the file from my downloads and selected firmware for another model body. Once I got the correct file on the SDcard it worked perfectly.
    Possibly my error can help someone else. I'll certainly be more careful the next time.
  12. Goldingd
    968
    287
    Ah, one difference on the back of the cameras, bottom left Function button, labeled Fn2 on X-E2, Auto on X-E2S
    got that from: Please login or register to view links
    And a bit of change on the grip, from the front notice a bit of difference:
    Those two from: Please login or register to view links and if yougo to that site, and look closer at the images, notice a difference in the grips surface where yur fingers would be touching. and of course the signage X-E2 vs X-E2S
  13. VintageJim
    Sep 13, 2018
    25
    54
    Michigan
    The body is 100% a X-E2S. Serial number on camera matches the box. Camera would NOT let me "upgrade" from 4.0 to 4.11. I just tried.
  14. tijuana taxi
    Oct 3, 2015
    1,016
    772
    Cambridgeshire, UK
    So you can't upgrade from 4.0 to either 4.11 or 1.11
    Think the answer is return the camera for a refund as it's faulty
  15. Goldingd
    968
    287
    Ok, was wondering if a way exists to check serial numbers to see what a camera reportedly is at Fujifilm, assuming the S/N is not forged. So far, just perhaps contacting Fujifilm, at perhaps this site: Please login or register to view links
    edit/corrected link
  16. zen
    zen Premium Member
    Apr 26, 2011
    383
    131
    new jersey
    whats the name of the firmware file that you are putting on the card? is it EXACTLY "FWUP0009.DAT" ? if the file is anything other than what i just posted, the camera will not recognise the file.
    VintageJim likes this.
  17. VintageJim
    Sep 13, 2018
    25
    54
    Michigan
    Yes, that's the file.
  18. VintageJim
    Sep 13, 2018
    25
    54
    Michigan
    Above image is with the X-ES2 v1.11 firmware, FWUP0009.DAT.
    This is when I try the X-ES firmware v4.11. FWUP0004.DAT.
    I tried with SD cards formatted with the camera and with cards formatted MS-DOS FAT with my MackBook Pro.
    I re-downloaded the FWUP0009.DAT file and tried again.
    Very curious.
  19. robert
    16,054
    5,561
    Can you fix the typos in the data under those pics?
    X-ES?
    X-ES2?
  20. GregWard
    4,784
    1,932
    I'm not suggesting you do this. But, as a possible explanation for how the camera got to be like this, I wonder if the X-E2 and X-E2S firmware are close enough to fool the validation by changing the filename? Like I say - I'm not suggesting you try to change the filename (I think that risks digging the camera into an even worse hole) but could it be that the previous owner changed the filename of the v4 firmware to fool the camera into accepting the upgrade?
    As far as your situation is concerned then I think you might need to talk to Fuji. Unless, of course, you're happy with the camera the way it is? That might mean not upgrading the firmware - but you could always talk to Fuji later if necessary?
