X E2S Pop Up Flash/ (H)-(l) Issue
Discussion in 'X-E1, X-E2, X-E2S, X-E3' started by Thomas Millard, Mar 12, 2018.
  1. Thomas Millard
    Thomas Millard New Member
    Mar 12, 2018
    Hello,
    Glad to be a member of Fuji's growing family. I am in the process of defecting from Canon after nearly 40 years and moving to the light of Fuji. However, I am having a few issues. I recently purchased an X E2s a few days back and while in 99% of the shooting experience, she has performed above and beyond. However, the 'pop-up' flash does not seem to want to work in manual modes, only in the automated SR mode. Granted, it is highly unlikely that I will ever use this flash with any serious shooting situation, still, I want to know that I can utilize the flash should I find myself in a situation where I would have to employ it. As I said, it works fine in the SR mode, however, upon returning to manual mode it ceases to function nor is there any flash icon on the screen When in the main menu in the Flash Setup section, I have 3 selections..
    1 Flash Mode
    2 Flash Compensation
    3 Red Eye Removal
    #2 and #3 work, but, #1 does not, I can not scroll up to #1, I am forced to #2 and #3.
    Pressing the Disp/Back button, I scroll down to Fn5 for the Flash Mode, press OK and nothing, simply returns to the previous page.
    My second problem. Like the pop-up problem, I do not see myself using this function often if at all, however, I can not seem to access the higher ISO (H)-(L) levels, both are greyed out.
    Problems aside, I am very happy to be apart of this community and look forward to additional Fuji hardware in the coming months.
    Thomas
  2. Im trying to remember how my X-E2s worked. I believe that when in manual mode you have to pop up the flash manually.
  3. Thomas Millard
    Mar 12, 2018
    Indeed, you still do. As I said it works fine in Auto SR mode, but manual, no-go.
  4. Oh your saying the flash doesn't go off at all. Sorry I cant help you.
  5. dem
    dem Premium Member
    May 31, 2015
    840
    457
    Is electronic shutter enabled?
    The flash can only work with mechanical shutter. The electronic shutter also stops you from using extended ISO.
    Blackcoffee87 likes this.
  6. Thomas Millard
    Mar 12, 2018
    Yep, that was the problem with both issues.
  7. Blackcoffee87
    Blackcoffee87 Well-Known Member
    Jul 7, 2018
    73
    55
    I have also noted that the expanded ISO settings, as well as the Low setting (ISO 100) are only available when shooting JPEG only. You can use any of the JPEG file size options, but RAW images cannot be recorded when using these settings.
    Likewise the option for these settings will be "greyed out" in the menus when utilizing a setting that records RAW.
