X-E2 Shutter Speed Problem in A mode after Firmware 4.01
Discussion in 'X-E1, X-E2, X-E2S and X-E3' started by Guilherme, Sep 12, 2017.
  1. Guilherme
    Guilherme New Member
    Sep 12, 2017
    Hi everyone,
    I have been having issues with the X-E2 shutter speed, on Aperture priority mode, since I updated from firmware version 1 to 4.01.
    When I set the camera to aperture priority mode so that I can control my aperture manually and let the camera decide on shutter speed automatically (this is what I use the most) the shutter speed never goes faster than 1/180 is often quantised to 1/160 and 1/56, which makes this mode useless.
    I tried switching between electronic and mechanical shutter and problem persists. Only solution I found was to shoot fully manual, when I choose both aperture and shutter speed manually, then I can go below 1/180. But it doesn't really work for my stile of shooting. It used to work perfectly before the firmware update.
    Has anyone experienced this? Is there a solution to that?
    Thanks for your attention,
  2. spudl
    spudl Premium Member
    Nov 25, 2014
    148
    124
    Reading.
    Are you using an Auto ISO setting, if so check what the minimum shutter speed, ISO etc are set to in that.
  3. Guilherme
    Sep 12, 2017
    Spudl, thanks for your quick response.
    I have tried both Auto ISO and fixed ISO (at 200) and none of these settings fixed the problem.
  4. spudl
    Nov 25, 2014
    148
    124
    Reading.
    Maybe try a higher ISO, say 3200, and see if that helps. Other than that I can't help, sorry!
  5. Guilherme
    Sep 12, 2017
    I'll try that just out of curiosity, but I think it should work properly at any ISO setting. The photos I make in daylight are way overexposed for any aperture larger than f/8. I think 3200 ISO would make it worse...
    I appreciate your help anyway.
  6. specLegacy
    specLegacy Premium Member
    Jun 4, 2013
    605
    194
    Houston
    1/180s is a bit of a clue. Maybe the camera thinks you have the flash popped up, or a flash installed on the hotshoe?
    Richard_R likes this.
  7. Guilherme
    Sep 12, 2017
    I'll look into that clue, but I never use flash on that camera.
    Thanks,
  8. trainer
    trainer Premium Member
    Jun 29, 2014
    2,999
    4,116
    upstate NY, United States
    Have you tried resetting the camera?
  9. Guilherme
    Sep 12, 2017
    You are a genius! Worked like a charm.
    I am still puzzled by what might have resulted in that weird behaviour... I'll post if I find out what the problem was.
    Thank you all for the help.
  10. trainer
    Jun 29, 2014
    2,999
    4,116
    I have been called many names, some not so nice but this is a first for me. Glad it worked out. Happy shooting.
    J J likes this.
