X-A3 Overexposure
Discussion in 'X-M1, X-A1, X-A2, X-A3, X-A10, X-A5' started by Márton Kopasz, Dec 5, 2018.
  1. Márton Kopasz
    Márton Kopasz New Member
    Dec 5, 2018
    Dear forum members!
    I've noticed this possibly software bug:
    Settings: A or S or M mode, Auto-ISO, multi metering, about 1EV overexposure present.
    I set average metering or turn off Auto-ISO the problem disappears.
    I hope I'm missing something, am I?
  2. Márton Kopasz
    Dec 5, 2018
    It has the newest firmware.
  3. versesinanelegiacmetre
    versesinanelegiacmetre Premium Member
    Oct 26, 2018
    131
    57
    Exposure is very subjective, that's why you have all the controls. Adjust the exposure to what you want it to be. Don't always go with what the camera "wants".
  4. Márton Kopasz
    Dec 5, 2018
    Music is subjective too like John Cage's 4'33 silence but an image missing plenty of details due to bad light metering is not a matter of taste to me. The metering on my beloved camera is consistent except for this one setting with Auto-ISO and multi-metering.
  5. Márton Kopasz
    Dec 5, 2018
    But that's true, there is absolutely a subjective side of the matter!
  6. Márton Kopasz
    Dec 5, 2018
    But I'd like to know if you have the same problems as me with X-A3-s (kit lens) there.
  7. Mike7
    Mike7 Premium Member
    Nov 13, 2018
    116
    134
    The first thing that comes to mind is the selection of the optimal measurement mode. In different situations, we have to choose the right mode. I remember the situation in which I was photographing in matrix mode, but the point mode was better.
  8. Mike7
    Nov 13, 2018
    116
    134
    All Auto modes are good only in certain standard (average) situations, it is better to first use the head consciously and then set the exposure. In many cases the M (manual) mode is the best, it often works well in A (aperture priority) mode with possible exposure correction.
  9. nu2digital
    nu2digital Premium Member
    Jan 5, 2015
    223
    206
    I'm not familiar with the X-A3, but I get results like this sometimes when shooting the X-T1. For me, it is usually because I have the metering linked to the AF point, or because my aperture and/or shutter speed are set to low for the Auto-ISO to compensate. In particular, when shooting with DR200 or DR400 set, the Auto-ISO gets limited to a minimum of ISO 400 or ISO 800 respectively, which is usually too fast for shooting in daylight at large apertures. Lastly, you might want to check that default sensitivity is not set too high in ISO Auto settings.
    John
    JimFenner likes this.
  10. JimFenner
    JimFenner Premium Member
    Aug 3, 2014
    383
    154
    Canberra
    No Exposure Compensation offset in operation?
    No Toy camera/other non-standard effect in operation?
    How do the RAWs look in post?
    Have you set your LCD to preview the exposure? Also is the LCD screen set below average brightness? Ideally the exposure should look right before ass well as after the take.
    If you have upgraded the firmware, need to turn camera off and on again right away.
    I'm rambling, good luck
  11. Márton Kopasz
    Dec 5, 2018
    Thank you for the answers.
    There isn't any exposure compensation and effect set, just Auto ISO and multi exposure metering, RAWs are overexposed but as soon as I set fix ISO or frame metering the exposure becomes perfect. If there's anyone out there with X-A3 and firmware 2.21 might confirm that it's a software bug or an unique case.
  12. Márton Kopasz
    Dec 5, 2018
    Default sensitivity was 200 and tried it in low lights with the same overexposure in the end.
  13. Márton Kopasz
    Dec 5, 2018
    All those overexposed shots show DR200.
  14. Márton Kopasz
    Dec 5, 2018
    Both the RAW and Jpegs are the same overexposed. I wonder if I miss something.
  15. Mike7
    Nov 13, 2018
    116
    134
    Ok, I will write it again. Have you tried to make the same frames using different methods of measuring light? Spot, center and matrix? I had such effects using in the difficult lighting conditions measurement in matrix mode. It helped to switch to point mode.
  16. Márton Kopasz
    Dec 5, 2018
    Yes, once setting average photometry fixed the issue, now it doesn't but no matter what I set, the problem only occurs with electronic shutter, mostly when Auto-ISO and DR200+ is set along it. I think I'll ask Fuji, once I figure this out I'll update here. And if you have the same camera and firmware, please make a test.
