Updating Godox TT685F for X-T2
Discussion in 'Fuji X Flash and Artificial Lighting (LED, etc.)' started by kcg, Dec 5, 2017.
  1. kcg
    kcg Premium Member
    Jun 13, 2013
    186
    23
    Having updated my X-T2 to the latest firmware, My Godox TT685F are not working properly. Godox site shows for TT685F update must be download along with G1 firmware. I have downloaded both but am unable to open either.When I double click I am asked what program should I open them with.
    Has anyone completed this upgrade? If so would be kind enough to send this 77 yo step by step instructions on how to do the update. Thank you in advance for any assistance you may provide.
  2. PXLPEEPR
    PXLPEEPR New Member
    Nov 28, 2017
    This is from the Godox website:
    "If your system can not extract compressed .man files, then you can simply rename the files to .rar."
    Hope changing the file extension works for you.
    John
  3. FredGUnn
    FredGUnn Premium Member
    Aug 9, 2015
    214
    74
    It worked fine for me. Download the G1 software and install it. If you are on Windows you may need to download a program that can open the .rar files. There are plenty but WinRAR is one with a fully functional free trial. If you needed to unpack the .rar file, do that now and then install G1. Download the TT685 firmware and unpack the rar file. Connect the TT685F via USB, wait for the driver to install (if needed), then open G1. Click the English button (or at least I had to do that) then select the file TT685F_V1.1.fri that you unpacked from the firmware .rar file. Hit Connect then Upgrade and the flash should upgrade in a few seconds. Hope that helps!
  4. jknights
    12,800
    2,688
    This software will NOT work on a Mac.
    Contact Godox and complain if you are using Mac as it needs to be addressed.
    If you are on Windows then make sure you have the correct drivers downloaded and installed.
  5. jcbgator
    jcbgator Premium Member
    Jun 7, 2013
    144
    59
    Miami, FL. USA
    This video updates the firmware for a Nikon version, but the steps for the Fuji version are the same. Remember this sofware only works on a Windows machine.
    Hope this helps...
  6. ojporqpojrewpo
    1,038
    382
    Godox does good flashes but the upgrade process is terrible and confusing. They need the same process like Cactus where you plug in the devices start the software and everything else is automatic. Olympus camera updates are nice too. Fuji could learn too.
  7. jknights
    12,800
    2,688
    Couldnt agree more.
    My Cactus units are child's play to update.
    ojporqpojrewpo likes this.
  8. mikegee
    mikegee Premium Member
    Oct 22, 2014
    810
    570
    Yonkers, NY
    Have flash on and via USB plugged in to computer, firmware update file in same folder as the Godox software and start the program. The program should find the flash and firmware.
  9. ojporqpojrewpo
    1,038
    382
    I have no problem with the procedure but I doubt a lot of normal users will be able to figure it out.
  10. jknights
    12,800
    2,688
    Wont work if you are a Mac user! Needs Windows to works.
  11. kcg
    kcg Premium Member
    Jun 13, 2013
    186
    23
    Have tried everything mentioned from above members. I am using MacBook Pro with parallels and win10. Downloaded to my windows hard drive in downloads. When I try to open I am asked if I want to convert to text file, spread sheet or HMTL. I have tried all three and only get errors for each.
    Files are not extensions but man files. Unable to change them.
    When I updated my X1T several weeks ago I had no such problem.
  12. ojporqpojrewpo
    1,038
    382
    It works with a VM. It's always good to have one around.
    inkista likes this.
  13. ojporqpojrewpo
    1,038
    382
    Rename the file to the extension "rar" and uncompress it.
  14. jknights
    12,800
    2,688
    Yes but luckily I have a Surface Pro 4 to use as I use my VM for very specific testing of new apps that I need to be able to have in a pristine environmnt. Not many users will want to build a VM or download one for such a simple task. Godox just need to port their app to Mac.
  15. ojporqpojrewpo
    1,038
    382
    Agreed. They need a Mac version and make it easier to use. I can't imagine that a regular user will figure out the current process.
  16. trainer
    trainer Premium Member
    Jun 29, 2014
    2,718
    3,349
    upstate NY, United States
    I upgraded my flashes but I am not sure why. :) Does anyone have an explanation on the two new custom functions,...wireless ID and Slave LED?
  17. kcg
    kcg Premium Member
    Jun 13, 2013
    186
    23
    Sounds good but unfortunately I am far from a computer expert. Can you tell me how to do is?
  18. inkista
    inkista Premium Member
    Jun 22, 2015
    208
    57
    Wireless ID only works with an XPro trigger. It lets you add a 2-digit ID code, to avoid interference with other folks using Godox gear on the same channel in your vicinity. Think of it turning your 32 RF channels into 3200 virtual/digital channels. So, for example, if you were planning on going to the Olympics where everyone uses radio triggers in the same place, you don't need Please login or register to view links any more. However. This only works if both the trigger and the flash is capable of the function, so I'm out of luck, since I also have two TT600s in the mix. [sigh]. (Canon shooters are used to this feature, since the Canon -RT system includes four-digit ID codes).
    The Slave LED function is so we can FREAKING FINALLY turn off those red LEDs on the front that continually blink to indicate the flash is in RF slave mode. :)
    I can confirm that, at least with the XPro-C and TT685C I have, that with the updates, both functions work.
    I also did all my firmware upgrades on a MacBook Pro, using a Bootcamp Windows 10 install. Sure, it's a PITA, but it's not brain surgery, either, to upgrade Godox gear with only a Mac.
  19. trainer
    Jun 29, 2014
    2,718
    3,349
    Many thanks for the information. All is clear now.
