Unclear Photo issues: X-T1
Discussion in 'Troubleshooting' started by Marley Buffett, Nov 13, 2017.
  1. colombiano
    colombiano Member
    Jan 6, 2017
    17
    Your settings were wrong and that's why images are not good.
    Your primary problem is that you are shooting at way too high ISO. With X-T1 and jpegs out of camera (no raw processing) I don't go above ISO3200 because the noise reduction is too strong and it reduces details. Also, set NR to -2 and you will get a bit more noise but also more details, image will appear sharper. ISO 25000 is a disaster in X-T1, you should never use it.
    As others said, you should learn more about exposure triangle (and I don't want to be patronising, just helpful). Until you master it, you will have problems because you will select inappropriate settings with camera and you will have problems because of that with image quality. Not even one of your shot needs speed more than 1/250 s (even with your people's shot, that's more than enough to prevent their motion blur, because they are almost stationary).
    Marley Buffett likes this.
  2. Marley Buffett
    Marley Buffett New Member
    Nov 13, 2017
    I'm starting to understand that I was prioritizing my functions incorrectly. I was choosing shutter speed, ISO then Aperture. I think I understand that I should choose ISO, Aperture (dept of field) then Shutter speed. Is this more correct?
  3. Marley Buffett
    Nov 13, 2017
    I didn't understand the F ring until I read about the exposure triangle so I was using the zoom to create depth of field. Now I understand that I don't need to do that. My firmware is body version 5.10 and lens is 3.21.
  4. Greybeard Photography
    Apr 23, 2017
    160
    47
    Its not so much prioritizing as thinking about the implications of each setting. It will likely be a balancing act.
  5. GregWard
    GregWard Premium Member
    4,146
    1,541
    I'm not sure there's so much an issue with the priorities so much as not having a full understanding of the best range for each aspect of the exposure triangle. Shutter speed can often be the one that you need to control the most - as too slow an exposure will mean either camera shake and/or movement blur. Although there are occasions when the latter is a good thing (eg water flowing over a waterfall) mostly these two things are to be avoided. So you need an exposure that is "fast enough" to avoid these. The difficult aspect is working out how fast that needs to be when, clearly, this is very scene dependent. A racing car needs a faster exposure than a sleeping cat!
    Next you probably want to think about the aperture. Ideally you probably want to be using f5.6 or f8 to get the best out of the lens. But this assumes a couple of things. Firstly that the depth of field (the amount of your image that will be acceptably in focus) is then appropriate for the image you want to take. A higher f stop will (all other things being equal) give more in focus. This can be a good thing (person in front of a famous sight) or a bad thing (same person but now you want the background blurred to focus the attention on the person). So sometimes you need to set the aperture as the priority. Bearing in mind that having the aperture too high gets you beyond the sharpest the lens can manage (something known as diffraction).
    The second consideration is the acceptable range of the ISO on the camera. Most manufacturers give their cameras access to ISO levels that are really best avoided. Opinions as to where - exactly - the acceptable range stops will vary. But I think most of us would happily shoot Fuji X up to 1600 and probably 3200 on occasion. So if you can achieve the shutter speed and aperture you'd like and the ISO is (say) 800 - then you should be good to go. If not then you need to re-consider because the key word is then compromise.
    More often than not that word (compromise) will be what you need to understand. But, to do so, you need to read up more on the exposure triangle I think.
  6. Irene McC
    Irene McC Premium Member
    Feb 4, 2017
    939
    637
    Cape Town, South Africa
    Photography is about capturing light.
    The way the light is captured depends entirely on your selected camera settings.
    These are determined by the Exposure Triangle.
    Shutter Speed - how long you are allowing light to enter your lens
    Aperture - the size of the 'hole' through which the light is flowing into your lens
    ISO - the sensitivity of your sensor and the way it responds to the light
    Each part of the three pillars plays a different role.
    It is vital to have an understanding of all these functions before making a
    decision on how to set your camera for a specific shot in specific conditions.
  7. Demoz
    Demoz Premium Member
    Mar 19, 2013
    445
    483
    mozambique
    Only very experienced photographers would get a reasonable exposure by choosing all settings manually. And usually when you want to take a shot, you do not have the time to adjust all of your settings first.
    Let the camera do the work for you and shoot in aperture priority. You choose the aperture on the lens and the camera calculates shutterspeed and ISO depending on the parameters you have set in the ISO menu (f.e. min shutterspeed 1/200 and max ISO 12800). You leave the shutterspeed dial on A (Auto).
    With these settings, you will be fine for normal lighting conditions and your image quality will improve. I`d guess the majority of us here shoots in aperture priority on most occasions.
    Try that and see how it works for you. Happy shooting.
  8. GregWard
    4,146
    1,541
    Yes I would agree with @Demoz. Also not a bad idea to set aperture priority with a wide open aperture (fastest that lens will allow) for a quick "grab shot". Simply set Auto ISO (but with a sensible upper limit (say 3200?). Having made sure there's "an image in the can" then slow down and consider the exposure triangle to take a set of images with "better" (more appropriate) settings. If you still have time then - especially in tricky lighting - there's nothing wrong with trying different settings (especially whilst gaining experience). Getting some shots really really wrong (as long as you got a right one as well!) can be a very good learning experience.
  9. Marley Buffett
    Nov 13, 2017
    OK, I like this idea. Another one I hadn't thought of. I can learn from my camera as it chooses the shutter speed when I choose ISO. Thanks for your thoughts.
  10. fujixacros
    fujixacros Premium Member
    Jan 8, 2017
    358
    99
    You choose the aperture.....
    Don't forget, that the Fujinon XF 18-55mm ƒ/2.8-4 R LM OIS is with variable aperture of F2.8-4 .
    When you increase the focal length, the maximum aperture size decreases :
    18mm F2.8
    35mm F3.6
    55mm F4
    Hope it helps.
  11. DougMac
    DougMac Premium Member
    Jul 27, 2017
    152
    144
    This made me chuckle. I spent almost all my photographic life, including the time I was a full time professional, shooting with cameras that were completely manual, including focus. I didn't own a camera with a zoom lens until 2002.
    I don't miss those days in the slightest. I don't miss the hours spent in the wet lab darkroom. I embrace new technology wholeheartedly. Having said that, though, I do think it is helpful for all photographers to have an understanding of the underlying principles. I spend a few classes covering this when I teach photography.
    My personal shooting style starts with an assessment of the situation. What is more important, controlling the depth of field or controlling the shutter speed? For most of my photography, I want to adjust the aperture to control depth of field, therefore I usually shoot aperture priority. I just shot my grandson running a cross country race. In this instance, shutter priority was more important, although I did want to have adequate depth of field. This is an instance where shutter priority makes sense.
    The last adjustment is ISO. I always start at the lowest possible ISO. I raise the ISO only to be able to shoot at the aperture I think is correct, correlated with an appropriate shutter speed. Landscape and general travel photography, along with portraiture is fairly static so I make sure my shutter speed is fast enough to allow me to shoot hand held. I use the 1/equivalent 35mm focal length, x2 if possible. For instance, if I'm shooting with the 18-55 @ 55mm, that's roughly 80mm in 35mm equivalency, so I'd like to shoot with a shutter speed of at least 160th/sec. Of course, good OIS like the Fuji lenses have allow me to shoot slower. Using the same example, with OIS I would feel comfortable shooting at 1/80 or even 1/40 in a pinch. If I was really brave, I might even go as low as 1/30, but even with OIS that's pretty low. My years of shooting hand held with slow film led me to develop good habits to shoot at pretty slow shutter speeds, but don't try this at home, especially if you're an old fart like me.
    Marley Buffett, bcirwin and Demoz like this.
  12. Demoz
    Mar 19, 2013
    445
    483
    mozambique
    I think its important to get Marley going. You don´t learn it all in 1 day. I think he needs to go out and shoot on aperture priority to get the exposure right. He will learn about the creative potential of aperture and can concentrate on composition. When he meets more challenging situations in low light or sports photography will be another day.
    I usually stick to 1/200 with my 35mm WR and manual lenses from 28mm to 85mm as well. I shoot mainly people and 1/200 is safe eough for movement blur. Also for camera shake on a hungover day.
    I own a GW690, which is great fun to shoot. And with plenty of sun here it is easy to expose, using the "sunny 16 rule". Shooting film has cured my habit of taking 5 shots of the same object too.
    Marley Buffett and DougMac like this.
  13. DougMac
    Jul 27, 2017
    152
    144
    This is a good group. I agree with whoever pointed out that we didn't condescend and suggest he needed something simpler. Each of us find ourselves in a different point on the path. I celebrate our common love for a creative endeavor.
    Marley Buffett and Demoz like this.
  14. MassillonFun
    MassillonFun Well-Known Member
    Apr 12, 2016
    97
    61
    Massillon, Ohio USA
    +1 to everything this man said.
    Thank you for typing it all out so that I didn't have to.
  15. Marley Buffett
    Nov 13, 2017
    Today is my first chance to practice everything you guys have told me. I'm shooting in an old church in Cirie Italy. The light is low so it will be a challenge. I'm happy I'm not the photographer but it's a good chance to practice. Any suggestions on shooting in lower light with my setup?
  16. Tilphot
    Tilphot Premium Member
    Mar 22, 2015
    734
    306
    Try to keep the ISO below 3200 and use your 18-55 on the wider end, so you keep the f/2.8 aperture. If you're shooting without a tripod, put OIS on – that way you should be able to get sharp images at 1/30th second or even below (depending on the steadiness of your hands).
    This was taken at ISO 2000 at 1/20th even without OIS (also in a dark Italian church):
    and this one at 1/6oth
    Also make sure to shoot RAW+JPEG and put Noise Reduction to -2. That way you'll have a little bit more noise, but you will also keep more detail.
  17. GregWard
    4,146
    1,541
    To my mind low light means you have to compromise and the lower the light the more compromise you need to make. So think about the "exposure triangle" and try to work out where the least bad compromises will lie? Depending on your choice of lens and how far away you are that will probably be the aperture. So I'd start with using this online tool before you leave...
    ... or you might want to find a similar tool for your Smartphone? Like I say it will depend on distance and the lens you are planning to use. But you will probably want to set the aperture as wide as you can go.
    Next you need to consider the shutter speed. OIS will help but that only helps the movements you are making accidentally. If you don't have OIS then the rule of thumb is the "reciprocal rule" - this means 1 divided by the focal length should roughly equal the shutter speed. So a 35mm lens would be 1/35th of a second. However, you need to apply the crop factor here as your are using an APS-C camera. So the angle of view of a Fuji 35mm is the same as a 50mm in Full Frame. Therefore, the reciprocal rule would be 1/50th of a second with a Fuji 35mm. But note this is only for YOUR movement.
    So you also need to consider the subject you are photographing. Now medieval churches are not normally known for their abrupt and substantial movements! So that aspect is unlikely to bother you. But shooting people within the church could be more problematic. This is where judgement needs to come in. But you need to juggle here. Too fast a shutter speed will give too high an ISO - and that will be to the detriment of your image quality.
    So the best bet is to recognise that IDEALLY you want to be shooting at f5.6 to f8 aperture, probably at least 1/50th of a second and preferably more like 1/250th if people are moving around. Then you ideally don't want the ISO to go over 800. It is very unlikely you will be able to achieve an exposure like that. That's why I said "ideally" those should be your exposure parameters. It's also why I said you will need to compromise. However, if you have time you should try to vary your compromise settings - particularly as I think you need a bit more experience in this area? So don't just choose one set of compromise settings - shift things around a bit. Try to brace yourself against the back of a pew (or whatever) and shoot at a slower than ideal shutter speed with the aperture wide open and the very best ISO you can achieve. Then try a faster (then faster again etc) shutter speed with the same aperture and with auto-ISO taking care of the ISO setting.
    You might even want to vary the aperture as well. But that's three variables to control and that might be too much. But DOFMaster will let you work out how much depth of field (what will be in focus) you'll get anyway. So that part of the triangle might be something you can largely ignore in this situation.
    Net - don't just use one setting - but "mix it up a bit".
  18. Marley Buffett
    Nov 13, 2017
    Noise reduction is the button to the right of the shutter speed? How do I change to Jpeg?
  19. MassillonFun
    Apr 12, 2016
    97
    61
    Massillon, Ohio USA
    Both the raw+jpeg and noise reduction settings can be accessed in the menus.
    I would make the changes there.
  20. MassillonFun
    Apr 12, 2016
    97
    61
    Massillon, Ohio USA
    Also, I find that a DOF calculator for my phone is very useful!
    I shoot with a lot of manual adapted lenses so it is indispensable for me.
    My favorite is HyperFocal Pro.
