TTL/Manual flash issues
Discussion in 'Fuji X Flash and Artificial Lighting (LED, etc.)' started by trivial, Feb 12, 2018 at 5:57 PM.
  1. trivial
    trivial New Member
    Monday
    I am shooting with an XT-2. My trigger is a Godox x-pro fuji, and I am using godox speed lights and an AD200.
    Here is the issue. While shooting in aperture priority (shutter speed auto), the camera will not let me set the flash to Manual... it will immediately go to TTL. I don't want TTL, I never use TTL. I don't really don't want to go back to using my Godox xt-32c (Canon trigger) with tape over all but the center pin... but at least it worked!
    By the way, I also have the XT1-F trigger and it has the same issue.
    Suggestions?
  2. Benjamin Kanarek
    Benjamin Kanarek Well-Known Member
    Oct 8, 2017
    78
    134
    Just dd a shoot for ELLE magazine using just 1 Godox TT685 and a shoot through $6 umbrella using a Godox X-1T trigger. I set my camera to a manual shutter speed to allow ambient light to my liking and used TTL for the model using only compensation values in TTL, i.e; + 0.3 or -0.7 or whatever and it worked perfectly. When in shutter priority it also works. Just go to the menu of the ca the X-T2 and switch to manual flash mode "et voila"!
  3. trivial
    trivial New Member
    Monday
    Well, that's the issue... when I go to the menu of the XT-2 and switch it to manual flash... it immediately switches to TTL.
  4. trivial
    trivial New Member
    Monday
    I should also note that the trigger and the flash are both set to manual operation.
  5. ebruder
    ebruder Premium Member
    Dec 29, 2015
    533
    210
    Cleveland, Ohio, USA
    Very odd. I just tested this using my XPro-2. The flash sync in the camera does show TTL, but the Godox trigger remains on manual as I was certain as I've used it like this many times.
    EB
  6. inkista
    inkista Premium Member
    Jun 22, 2015
    257
    78
    Use M on the trigger, not the camera menus. A lot of non-Canon systems have their M power levels "faked" by using TTL adjustments. Just because the camera or flash says the flash is in TTL doesn't mean you're not using M power levels. :) Just use the XPro-F in M, and see if it does what you think it should do. If it doesn't, then you have a problem. But the trigger/menu communication will not be identical to using Fuji gear. The only system I know of where the cameras and OEM flashes will correctly indicate TTL/HSS and full two-way menu communication happens is Canon, which leads me to suspect Canon's flash menu communication protocol is what was reverse-engineered when creating the system.
    Nikon speedlights also have to be in TTL on Phottix Odins to have M power level control. When I use a TT350-O to master my TT600 and TT685 M power levels, my GX7's flash control menu shows the flash is set to TTL and the menu selection is greyed out and cannot be changed. It's non-intuitive, but that's actually the way a lot of these radio TTL systems work.
    trainer likes this.
