Thinking of returning EF-X20 flash; is there another way to bounce?
Discussion in 'X100F, X100T, X100S, X100, and X70' started by Tselem, Jan 1, 2014.
  1. Zazoh
    Zazoh Member
    25
    Mico TX
    My solution, at least for the time being. You know how we photographers are NEVER satisfied with our gear.
    I sold all my Canon DSLR stuff, but they didn't want my 430EX, which has a great refresh rate and long battery life. So, while I was going back and forth on the best off camera solution, I picked up, from Amazon, Cowboy Studio remote triggers. It works two ways, as stand alone off camera flash that I can place anywhere, or in commander mode triggered by the hot shoe but also firing on camera flash. Okay, I can even put on camera, but look at the size compared to the camera, kind of ridiculous looking on the camera.
  2. rpavich
    rpavich Premium Member
    Jul 7, 2013
    5,766
    1,909
    WV
    I've been down this road more than once...and did it all...foil covered shields...tape, gaff shields....turning the flash down as low it would go...using the onboard as a commander, Canon extension cable, holding it in my hand with a trigger on camera...none of it satisfied me so that I got good "side lighting" without bleed into faces and that horrid "center pupil catchlight"
    I ended up buying an EF-42....it's not the greatest flash in the world...but it swivels and that's what's needed.
    I also have Buff Cybersync triggers for off camera flash and a few Yongnuo manual flashes so I'm covered for bounce-TTL, and manual off camera flash.
    In my opinion...none of these kludges work as well as just spending $150.00 on the EF-42 (with the added benefit of TTL).
  3. Darkaeden
    Darkaeden New Member
    Jun 30, 2016
    Has there anyone found a reliable solution to bounce with the ef-x20 attached to the camera hot shoe?
    I really would like to tilt the flash...
  4. Gilzuma
    Gilzuma New Member
    Nov 10, 2013
    30
    Canada
    I found this: it won’t be ttl though...Please login to view links
