50-230mm Testing OIS & low light performance..........
Discussion in 'Lens-Specific Photo Archive' started by Madhav Bodas, Dec 6, 2017.
  1. Madhav Bodas
    Madhav Bodas Premium Member
    Apr 15, 2016
    176
    115
    Took these tonight at Auto ISO, DR400, 1/15s and processed using X-Trans & LR6.........
    AndresC, Lisa and DaveX like this.
  2. Hugh Jammer
    Hugh Jammer Premium Member
    Nov 4, 2017
    179
    71
    If you're using RAW files what benefit does using DR400 give? Isn't that predominantly a JPG functionality, and will simply underexpose a RAW file by two stops and use a higher ISO, at least 800, to boot.
    lawsofphysics likes this.
  3. DaveX
    DaveX Premium Member
    Jul 21, 2017
    1,532
    1,957
    South Coast UK
    Two very nice shots, that XC 50-230mm is actually a very good lens in low light.
    Lisa likes this.
  4. jknights
    13,901
    3,350
    Oliva, Valencia, Spain & Cornwall, UK.
    Where were these images taken?
  5. Madhav Bodas
    Apr 15, 2016
    176
    115
    As I understand, DR feature does not change exposure, which is dependent on f stop and shutter speed. What it does is that it will store the RAW image with one or two stops of lesser analog gain. I thought it will be a good idea to have the leeway in PP to decide how much gain to apply and where. I knew that at that lighting condition, XE2 will choose ISO 6400 by default.
    You are right. I could have taken the shot at maybe ISO 800 as well and adjusted in PP. I somehow have a bias for ISO 6400 being used by XE2 because I think the in-camera noise reduction algorithm used by Fuji works so well at that ISO.
  6. Madhav Bodas
    Apr 15, 2016
    176
    115
    First one is a very famous Al Noor Mosque on Buheira Corniche in Sharjah. The second one is Al Taqwa Mosque in Al Majaz park, Buheira Corniche, Sharjah.
  7. Madhav Bodas
    Apr 15, 2016
    176
    115
    Thanks. Surprisingly good focussing in low light.
    DaveX likes this.
