swapping tripod collars???
Discussion in 'Native X-Mount Lens Forum' started by barryd, Dec 5, 2018.
  1. barryd
    barryd Premium Member
    Nov 10, 2012
    243
    89
    Monroe, GA - USA
    Will the tripod collars of the 50-140mm and the 100-400mm swap. I think I would like to have a larger collar to handhold and the 50-140mm has the larger collar.
  2. visorvet
    2,055
    630
    I don’t believe that will work. I just put a long Arca plate on the foot to make it easier to hold.
  3. Fujiphotog
    2,034
    2,186
    No, because the diameters of the two lenses are different so the holes for the screws are different.
  4. barryd
    Nov 10, 2012
    243
    89
    Monroe, GA - USA
    of course....I should have thought that through!
  5. barryd
    Nov 10, 2012
    243
    89
    Monroe, GA - USA
    Is there a good reason why Fuji made the 100-400 so short? I guess it could be a weight consideration...assuming that most users would be using a tripod.
  6. Jeff123
    Jeff123 Premium Member
    Feb 11, 2014
    455
    163
    Colorado USA
    Try these Hejnar collars. They are sweet. The tall ones have enough clearance so I can carry the lens with thick gloves on.
