Remote Shutter Release for the X-Pro2
Discussion in 'Fuji X Accessories' started by Ed Vatza, Mar 13, 2018.
  1. Ed Vatza
    Ed Vatza Active Member
    Jul 5, 2017
    85
    41
    Lehigh Valley, PA
    Okay, I am puzzled. I have an X-Pro2 with the RRS L-bracket. I just bought the Fuji remote and I have a Canon remote from a previous life. Both will fire the X-Pro2. That's not the issue. The issue is neither will work with the camera/bracket mounted on the tripod in the vertical/portrait position. Definitely not the Fuji remote. And while I can squeeze the mount into the bracket with the Canon, it is only with the risk of damaging the door to do so.
    I know I can't be the only person with this issue. Any solution other than turning to the Fuji Remote app for my iPhone when I want to shoot in portrait which, thankfully, isn't often.
  2. Shadowside
    Jun 24, 2013
    2,252
    2,011
    Winnipeg, Canada
    Not sure how you will solve this problem, but I can tell you how to avoid it completely...
    Go old school, get a mechanical cable release for the shutter button - these work in all positions and are inherently WR too :)
    pandoraefretum and Marty M like this.
  3. tijuana taxi
    tijuana taxi Premium Member
    Oct 3, 2015
    1,059
    835
    Cambridgeshire, UK
    Right angle adapter for the mic/remote socket or a bit of customising Dremel action.
    fugu 82-2 likes this.
  4. Goldingd
    1,016
    308
    Cable relief spacer
  5. Ed Vatza
    Jul 5, 2017
    85
    41
    Lehigh Valley, PA
    Good point. I have a mechanical release that I used to use with my Leica. I forgot about it and having a soft button mounted in the shutter release button didn't serve to jog my memory! :)
    Shadowside likes this.
  6. Ed Vatza
    Jul 5, 2017
    85
    41
    Lehigh Valley, PA
    Nothing RRS make it cheap! I'll have to think about this.
  7. Shadowside
    Jun 24, 2013
    2,252
    2,011
    Winnipeg, Canada
    That's crazy, they sell a bracket that is made specifically for tripod mounting and you can't access the cable door when using it... and we all know how rare it is to use a cable release when we use a tripod!
    For the amount that RRS charges for the L Bracket it should include the bit you need in order to use it with the cable release. Don't get me wrong, I love their products the quality is amazing and the customer service is top drawer stuff too. But overall product value is at times compromised by the high cost.
  8. ebruder
    ebruder Premium Member
    Dec 29, 2015
    627
    257
    Cleveland, Ohio, USA
    I was not going to pay RRS the $180 (?) for the L bracket and then an additional $66 to fix their inadequate design.
    I purchased a Meng brand L bracket off of ebay for $20.00+, and use a mechanical release as was previously suggested. The bracket is great, not so much so a mechanical release. I got very spoiled using a Canon electronic release on my XPro-2, but can't use it in portrait orientation on a tripod with the L bracket.
    This is a design fault, but I don't if by Fuji or the bracket makers. Frustrating.
    EB
  9. Shadowside
    Jun 24, 2013
    2,252
    2,011
    Winnipeg, Canada
    Well, after snooping around a bit, here's a thought. If you are using the Canon or Canon compatible electronic release with the 1/8" micro 3 conductor plug (I use one of these) then this might be your huckleberry:...
    Sorry, I guess admin doesn't approve of links to Amazon... Just do a Google search for 'Right Angle 3 Contact male to female 1/8" extension". There are several very cheap extension cables where the male end is right angle and might work without the need of the extra bracket.
  10. ebruder
    Dec 29, 2015
    627
    257
    Shadowside, many thanks
    EB
  11. fzdp
    fzdp Premium Member
    Aug 30, 2017
    179
    132
    European Union
    I am using x-t20 but I have the same issue ... There is a problem with the Mengs plate and some other brands - the vertical rail is to slim. So even if you use some extension, the opened door go trough the l bracket and it can be damaged by the tripod. This drives me crazy... I ended up using two l brackets when I know I want to use a tripod. One is with the grip (I am to lazy to take it off), second one is to give enough space for vertical position. And the second one, universal one, is filed to give access to the battery compartment... Ugh...
    At the same time, the shutter button feels so flimsy, that I do not want to break it with the mechanical release cord, and Canons release feels much better... I would like to know if there is a proper l plate for those cameras, with a grip, and its price is not ~100$...
