Optical viewfinder for your X
Discussion in 'General X Camera Forum' started by robert, Sep 30, 2017.
  1. robert
    15,282
    4,947
    Just finished this little project, using repurposed 35mm viewfinder parts with framelines from a Canon Sure Shot Owl. The housing is 3D printed.
    Good match for the 23mm Fujinons.
    The Owl has perhaps the largest viewfinder in a P&S, with 0.68x magnification, and close up marks. These cameras can be acquired for a song on ebay. (I paid $7.33 for one, and $10 for a second, including shipping.)
    Total weight when assembled 14g, or 0.5oz.
    A great big view with zero weight!
    zen, dixeyk, Ken Ford and 9 others like this.
  2. johant
    johant Premium Member
    Apr 25, 2015
    1,938
    911
    Netherlands
    Did you glue the hot shoe adapter underneath? Brilliant idea.
  3. robert
    15,282
    4,947
    The viewfinder optics are removed and placed into a 3D printed housing with the accessory foot.
    johant likes this.
  4. pszilard
    pszilard RemektekMedia.com
    Sep 14, 2011
    2,338
    734
    Sydney, Australia
    Can't see any images. Can anyone?
  5. Ted W
    Ted W Premium Member
    May 3, 2013
    357
    71
    New South Wales
    Mmmmm, Quite innovative.
  6. darkslide
    darkslide New Member
    Aug 20, 2017
    Yes.
  7. yendikeno
    yendikeno Premium Member
    Feb 28, 2014
    953
    271
    Neat idea!
  8. Simon Green
    Simon Green Premium Member
    Mar 20, 2013
    532
    354
    north west hampshire, uk
  9. johant
    Apr 25, 2015
    1,938
    911
    Netherlands
    Obviously, otherwise I would not have responded.
    Are you using Tapatalk? That often has a problem with showing images.
  10. Ken Ford
    Ken Ford Well-Known Member
    Mar 7, 2011
    235
    62
    Suburban Chicago, IL USA
    Very nice! Is the project available on Shapeways?
  11. robert
    15,282
    4,947
    It will be. Having some technical issues with the store but should have it sorted soon
    Ken Ford likes this.
  12. Ken Ford
    Mar 7, 2011
    235
    62
    Yay! Is the optical pack in the Owl behind plastic? I’m curious how clean of a donor camera is needed. If the optics are encased behind windows that opens up the prospects considerably.
  13. robert
    15,282
    4,947
    The two donor cameras I bought were not very very clean, but the optics were easy to clean up with a microfiber cloth. There are three optical pieces, the two outer ones are open to the elements.
  14. Ken Ford
    Mar 7, 2011
    235
    62
    Thanks, Robert - the search begins!
  15. robert
    15,282
    4,947
    Here is the list of camera models that have these viewfinders. Each line lists an identical model; the alternate names were sold in different markets.
    • sure shot owl - prima af-7
    • sure shot owl pf - prima af-9/date
    • sure shot owl/date - prima af-8/date
    • snappy lx - bf35 - prima bf
    • snappy lxII/date - prima bf-8/date - BF35D
    • snappy lx/date - prima bf-7/date - BF35 QDN
    I bought a Sure Shot Owl, and a Snappy LX. The Snappy LX did not have the close-up marks on the framelines.
    Bear in mind for close-up shooting (anything closer than about 3 feet) with a Fuji, use the EVF or LCD.
    For most applications including street shooting the close-up marks aren't really needed.
  16. Ken Ford
    Mar 7, 2011
    235
    62
    My donor Sure Shot Owl should be delivered in a day or two. Have you had any luck uploading the project?
  17. robert
    15,282
    4,947
    Hi Ken, I have a couple of already printed ones here, message me your address and I'll mail you one. :)
  18. Ken Ford
    Mar 7, 2011
    235
    62
    Thanks - on the way!
  19. Ken Ford
    Mar 7, 2011
    235
    62
    Ok, the housing is here and looks great. Robert, can you provide guidance on how to best extract the finder from the donor camera? Also, does the housing need any treatment before use (i.e. Bestine?)
  20. robert
    15,282
    4,947
    Hi Ken, no special treatment, just a couple of drops of glue (superglue) to secure the top, placed into the two holes. Make sure it doesn't get on the optics!
    As far as taking the camera apart, since there are so many variations of the Sure Shot Owl/Snappy, this attached pdf might vary somewhat from your camera. This was something I found on the net, you don't need to remove the battery door or the shutter button.
    But basically, remove all the screws you can find, and then split the front part off from the rest of the camera. It should pry apart fairly easily with a screwdriver.
    This should expose the the black plastic piece that covers the viewfinder parts. Remove that black piece and then pull the three optics out and place them in the same relative locations in the housing.
    • owl.pdf
      File size:
      108.4 KB
