No Info in X30 EVF
Discussion in 'Fuji's Small Sensor X Cameras' started by merlinus, Sep 13, 2018.
  1. merlinus
    merlinus Premium Member
    Jun 17, 2017
    624
    961
    Northern New Mexico
    All of a sudden, there is no info in the EVF until I half-depress the shutter button, and even then the choices I have made (e.g. remaining no. of shots) do not appear. Same is true of the LCD.
    A search of the manual did not reveal anything that might be causing this. Can anyone help?
  2. fujixacros
    fujixacros Premium Member
    Jan 8, 2017
    708
    245
    Fr
    Hello,
    Did you try the DISP/BACK button ?
    And see :
    Standard Display : The items shown in the standard display can be selected as described below.
    1 - Select[SCREEN SET-UP] ->[DISP. CUSTOM SETTING] in the setup menu.
    2 - Highlight items and press[MENU/OK] to select or deselect. Selected items are indicated
    by a check mark
  3. merlinus
    Jun 17, 2017
    624
    961
    Northern New Mexico
    I have done all this. The EVF has no info when turning on the camera. Some but not all of the selected info appears when half-depressing the shutter button, but it disappears completely when letting go of it.
  4. merlinus
    Jun 17, 2017
    624
    961
    Northern New Mexico
    On a whim, I just tried it again. At first, Display/Back button did nothing, and holding it brought up the button assignment menu. I turned the camera off, then on again, pushed Display/Back and now everything is working perfectly.
    Thanks!
  5. fujixacros
    Jan 8, 2017
    708
    245
    Fr
    Good to know.
    I didn't talk about camera body reset (even if you haven't used it), because most of the time, I like to understand where it may come from.
    merlinus likes this.
