Next Fuji X camera? - Advice sought
Discussion in 'General X Camera Forum' started by BernX, May 14, 2018.
  1. BernX
    BernX New Member
    May 14, 2018
    St Albans, United Kingdom
    Hi everybody,
    I've just joined this forum.
    I've owned a Fuji x20 for 5 years and taken lots of images with it.
    At this stage, I feel it's time to move on to something bigger and better within the Fuji X family.
    I wondered if I could please get your advice on what to consider.
    I tend to shoot street photography, people, buildings and small music concerts.
    I was admiring the x100f for some time (and still do), but an important factor in my decision is that I now have a walking issue caused by MS which limits my mobility. I feel that the fixed prime lens on the x100f would make life difficult for me (x20 contains a decent zoom lens which means that I can stay put and shoot from where I am if necessary).
    Weight and size is also an issue in my consideration.
    Is it worth looking at the X-E3 plus an X zoom lens (18-135mm)?
    Really appreciate any feedback on this; thanks in advance.
    bern
  2. Spock66
    Spock66 Premium Member
    Apr 21, 2013
    364
    201
    Hi Bern - welcome to the forum.
    I think X100F would meet all of the above subjects except perhaps music concerts, but you should also consider the wide and tele-adapters to extend it's capability. If you are used to a zoom you may find it limiting at first, but once mastered its a great camera to use.
    If you do go the X-E3 route I would suggest the 18-55mm as the best option, you really need to get to a dealer where you can try out both options for comparison.
  3. beakhammer
    11,156
    7,547
    Whatever Fuji body feels right in your hands would be great, and a zoom lens or two makes sense. The 18-55 is a great lens.
  4. beakhammer
    11,156
    7,547
    I have used an X-E2 for years, and think the X-E3 is a great choice. I have an X10 as well, so have an idea of what your X20 is like.
  5. jedorme
    jedorme Premium Member
    Apr 21, 2012
    306
    75
    Indio, CA
    I've used X-100, X-100S, X-E2, X-Pro1 & now X-Pro2, all of which are in the rangefinder style of Fuji X cameras (in contrast with their X-T series which are styled to be more DSLR like in appearance & function). If you have enjoyed the X-20, then I think you would also have an easy adaption to the X-E3. It doesn't have the optical viewfinder like you have been using, but has an excellent electronic finder. You may want to try this out to make certain it works for you. Staying small & light weight with an optical finder would probably mean getting the X-100F. But given you've also been working with some zoom capabilities, then the X-E3 with the fairly small & excellent 18-55 zoom might be a better option. The 18-135mm is also an excellent lens but much larger & heavier to use on a small body like the X-E3. Good luck with whatever you decide to do.
  6. The Judge
    The Judge Premium Member
    Sep 15, 2016
    120
    98
    Kennewick, Washington, USA
    Yes, though that 3.5-5.6/18-135 lens weighs 490 g. For me mobility is a problem but carrying weight is even more of a problem. I would do some testing after buying a zoom lens to make sure your copy performs to your standards of sharpness, but overall there is nothing wrong with superzooms. Do you have the money to get a compact prime lens in addition to a superzoom? This way you can go outside either optimized for weight or for reach depending on how you're feeling.
    The 2.8-4.0/18-55 is a very nice lens as well and you can buy it in a kit with the X-E3.
  7. The Judge
    Sep 15, 2016
    120
    98
    I know this is a sensitive topic and I mean no offense (I've a fairly debilitating chronic neurological condition as well) but if you need to use a wheelchair your lens needs might change. You may be able to get away with carrying heavier gear than by walking. And your social interactions might change and you will find people are more patient when taking their portrait or doing street photography.
    As an aside, a public librarian where I live has progressive MS that he manages by eliminating gluten and dairy and with meditation and yoga. He has bad days but he has stopped the progression with his diet change. He swing dances at a group I go to (I had to stop dancing due to heart problems) and is also a self-published sci-fi author.
    For that X100 itch: you can pimp out your X-E3 by getting a prime lens and getting an external viewfinder that rangefinders used to have before viewfinders were integrated into the bodies. Sure, the X100 is modelled after the Leica M3, but you can have one up on that by aping the IIIf.
  8. Wayben
    Wayben Member
    Feb 25, 2018
    39
    23
    Iowa
    +1 for the X-E3/18-55mm combo. My 18-55mm seldom leaves my X-E3, it's a great combination. Small and light-weight, with tons of picture taking capabilities!!
  9. surfdogs
    surfdogs Premium Member
    Feb 26, 2017
    133
    92
    Davis California
    No question, if possible, get to a shop and feel them in your hand for comparison. I have both X100F and X-E3. The previous suggestions all make sense. I don't own or want the 100F add on lenses. Simply because the 100F is, for me, meant to be, small, agile and near invisible. I'd be curious to know, using your X20, where do you most often find you're shooting focal length wise? Yes, 18-55 is great, and also in my case .. quite often on my X-E3. But, it's shorter than the zoom you're accustomed to on your 20. BTW, I bought, then sold 18-135mm lens. It might be great for you. For me, it was heavy. Which doesn't mean I don't sometimes use the 55-200mm on my 3. Also, though I don't own any, the Fuji C series lenses are lighter and cheaper. One of those on an X-E3 might be a great second lens after the 18-55.
  10. rokphish
    rokphish Premium Member
    Jan 28, 2017
    558
    833
    Indonesia
    I have X30 and when I move to bigger and better I got the X-T20. Seems like X30 on steroid except the zoom lens where X30 still better in that regard.
    I now also have X-Pro1. Having had tilt screen for quite awhile, going with non tilting screen is the first annoyance to come to mind out there while shooting. I don't use it every time when I shoot, but when I need it, it's a pain to not have it.
    After months of using X-T20 AND X-Pro1, I circled back to the X30 and having fun. This last one month trip to China and Hong Kong I took X30 and X-T20 with two lenses. I didn't take a single shot with the X-T20.
  11. Mervington
    Mervington Premium Member
    Jan 25, 2015
    330
    142
    My wife has had MS for over 6o years. Thus, I know a little about the problems it causes. She isn't a photographer as such, but when we are out I usually give her an X-M1 to use. It certainly would not be my X-Pro 1 or X-T1 that I have, purely because of the weight. As for a lens, it would be the 18-55 or the 27mm. The latter keeps the weight very down, but the former gives decent range. Optically, they are both super.
    I sometimes use the X-M1 myself (in fact I have two) both costing less than £150 used with a top warranty. After the best part of two years, they still surprise me with their performance. One downside - no viewfinder, but do have a tilting screen.
    As others have said, the opportunity to 'feel' the various bodies and lenses would be a great advantage.
    I wish you well!
  12. kenbennett
    kenbennett Premium Member
    Jun 26, 2013
    3,014
    1,633
    North Carolina, USA
    I don't own the 18-135, though I've used a friend's. My personal feeling is that the 18-55 would balance better on the small XE3 body.
    Good luck figuring it all out.
  13. Just Browsing
    Just Browsing Member
    May 7, 2018
    69
    I'm as much a Fujiphile as everyone else here seems to be, my last few cameras have been Fuji, but don't limit yourself to just Fuji. Many other manufacturers out there all producing nice small self contained cameras with zooms, Canon, Sony and Panasonic spring to mind.
  14. gremlin75
    gremlin75 Premium Member
    Feb 1, 2016
    196
    86
    I'd try out the x-e3 and x-t20 to see which feels better for you.
    the 18-55 is a little smaller then the 18-135 but will also be a little "shorter" then you're used to with the x20. the 18-135 is a very nice lens as well and will actually be "longer" then you're used to but the trade off is its size.
  15. BernX
    BernX New Member
    May 14, 2018
    Hi everybody,
    Thanks so much for all your really helpful replies.
    All great advice.
    Today, I visited WEX's new store in Whitechapel, London and looked at the XE3 with both the 18-55mm and 18-135mm lenses.
    The 55 was perfect for the camera body whereas the 135 was far too heavy and bulky.
    I bought the camera with the 55 and really look forward to getting to grips with it.
    Thanks again and best wishes,
    bern
    Tim Foster and inkista like this.
  16. Reg Isteredtoviewlinks
    Reg Isteredtoviewlinks Premium Member
    Jun 9, 2018
    103
    33
    Did you spot the Curry's deal? X-E3, 18-55, and the 50mm for £983.
  17. SixstringSlinger
    SixstringSlinger Premium Member
    May 17, 2018
    102
    48
    SoCal, USA
    Congrats on your new Fuji rig Bern! Enjoy!
