Horizontal banding- adapted lens
Discussion in 'X-T3, X-T2, X-T1, X-T20, X-T10, X-T100' started by Leonardo Kibanoff, Jul 11, 2018.
  1. Leonardo Kibanoff
    Leonardo Kibanoff Member
    Apr 11, 2017
    65
    Parlin NJ
    Hey All-
    Just an observation and really just a curiosity since it only happens under this one condition
    Noticed some horizontal banding that moves vertically when using an adapted lens
    that happens only when pointing to my chandelier that has LED candelabra bulbs- and only at these bulbs,
    My hats in the house are also LED and the symptom doesn't show up or even pointing to my PC screen
    again not complaining about it, just curious why it does it? anyone know?
  2. Goldingd
    971
    287
    Electronic shutter selected?
  3. Richard_R
    8,377
    9,211
    and/or a shutter speed that synchronises with the 60hz refresh rate of US AC power.
  4. Jackpinoh
    Jackpinoh Member
    Aug 27, 2017
    The camera processor does not read the entire image sensor at the same time. Artificial lighting powered at 50 hz or 60 hz is actually flickering at those frequencies. Cameras with electronic shutters can capture different levels of light during sensor readout unless the shutter speed is an exact multiple of the lighting power frequency. This results in banding in the image.
  5. Leonardo Kibanoff
    Apr 11, 2017
    65
    Parlin NJ
    Electronic shutter is off, So, why just the chandelier? And no other LED's in the house?
    Just to be clear- I'm not actually taking photos, just pointing at the chandelier, the banding is active and travels from bottom to top of rear displace (evf also) like an old black and white tube tv
  6. magmouse
    magmouse Premium Member
    Jul 19, 2015
    826
    1,392
    London, UK
    A lot of LED fittings have switch-mode supplies that run at much higher frequencies than the mains supply. Depending on this frequency, they might create a strobing effect with the refresh rate of the sensor/rear screen. Other LED types might have different frequencies, so I am not surprised it is just one type that exhibits the effect.
    Leonardo Kibanoff likes this.
  7. Jackpinoh
    Jackpinoh Member
    Aug 27, 2017
    Any bulbs (LED, incandescent, or florescent) plugged into household current will produce the effect--voltage or each is switching continuously at 50/60 cycles per second and going through zero twice for each cycle (AC current is a sine wave), although the light from the source element doesn't decay as fast and never is completely off, it does dim significantly twice each cycle. What you see on your screen or in the EVF is being transmitted from the sensor which is being read out sequentially while the light is changing.
  8. lawsofphysics
    lawsofphysics Premium Member
    Apr 17, 2013
    2,639
    1,045
    If the mechanical shutter is used, it is impossible to see banding from modulated light sources – such as LEDs.
    I can not think how an adapted lens could cause banding when the mechanical shutter is used.
    It would help to see an example.
    I will speculate what you see is not banding but has something to do with lens ghosting. Lens coatings and lens internal design can make ghosting artifacts more likely. FUJIFILM lenses are designed to minimize ghosting because the design team uses simulations taking the sensor location and camera internal surfaces into account. Some adapted lenses may have low ghosting levels while others may have very high levels. If the ghosting levels are low it's just good luck.
  9. Leonardo Kibanoff
    Apr 11, 2017
    65
    Parlin NJ
    Mechanical shutter is used, never had the need to go electronic
    I'm pretty sure it's not ghosting.
    I'll try and get a quick clip or at least a still and post when I get home tonight
  10. magmouse
    Jul 19, 2015
    826
    1,392
    London, UK
    The OP is referring to banding on the EVF and rear screen, not in images, so it will be down to the particular light source strobing at a frequency that interferes with the screen refresh rate. Not sure why this would appear with adapted lenses specifically, though.
  11. Leonardo Kibanoff
    Apr 11, 2017
    65
    Parlin NJ
    This is what I'm seeing
    Adapted Minolta 50mm macro
    Mechanical shutter only
    just pointing cam to chandelier
  12. DanGleabols
    DanGleabols Premium Member
    Feb 28, 2014
    243
    108
    Halifax, UK
    Banding is due to electronic shutter + shutter speed + flickering light.
    You have the camera set to mechanical shutter so banding will not be present in final photos (although some inconsistency of exposure over a series of photos may be seen)
    The EVF and LCD work by effectively producing a video from the sensor using the electronic shutter (even though you are using mechanical shutter only for the Actual picture) this makes sense as using the mechanical shutter to produce the preview video would 1) wear out the shutter very very quickly 2) be noisy as hell.
    Normally you can mitigate the banding with evf by syncing the shutter speed with the frequency of the electrics, but as you can't control this for the preview so your stuck with it.
    As to why one light is worse than others; I'm no electronics expert but you can apply electronics to smooth out the flickering and I guess some have better design than others.
    lawsofphysics likes this.
  13. lawsofphysics
    Apr 17, 2013
    2,639
    1,045
    Thanks. I guess I missed that.
    I agree the banding must only be a function of the EVF scan rate since the banding is cause by aliasing between the scan rate and the light modulation frequency.
    I can not think of how the lens alone could make any difference.
    So,
    • if the camera was on a tripod
    • when the effective angle of view (I.e. composition) is identical for both lenses
    • when the light reaching the sensor (exposure) is identical
    it's a total mystery how the banding could be different.
    magmouse likes this.
  14. Leonardo Kibanoff
    Apr 11, 2017
    65
    Parlin NJ
    Not sure if I mentioned- this does not happen with native lenses
