Fuji X100F
Discussion in 'X100F, X100T, X100S, X100, and X70' started by Mike Gorman, May 7, 2017.
  1. Shuffles
    Shuffles Member
    Feb 21, 2014
    33
    I love my X100F, but it is true that with glasses on it may be a little harder to see all the edges of the VF. So, I generally shoot without my reading glasses and adjust the diopter to my vision. Overall, I'd say the X100F's VF (both OVF and EVF) is excellent.
    I do wish we could change the color of the overlay on the OVF, though. Sometimes the white info can get lost inside a bright subject.
    Solo with others and Mike Gorman like this.
  2. Mike Gorman
    Mike Gorman Premium Member
    Mar 4, 2017
    518
    311
    West London
    That shop is now long gone, it went when Jessops crashed!
  3. jknights
    13,013
    2,812
    :D:(
    I guess you need to go into London for best choice.
  4. Mike Gorman
    Mar 4, 2017
    518
    311
    West London
    JK you are quite right, by the way the Uxbridge Jessops was very small, and if it wasn't made by Nikon or Canon they didn't stock it!
  5. Mike Gorman
    Mar 4, 2017
    518
    311
    West London
    I still maintain that the VF of the X100F spoils what is indeed a cracking little camera, and I don't understand why, if Fuji can get the X-T1/2 right surely its not too much to ask for the same in an RF camera?
    And even Leica have recognised that and are boasting of an improved VF in the M10!
  6. Brierfield
    Brierfield New Member
    May 19, 2014
    I tried an XPro-1 a year ago, and I could not use the OVF because of my astigmatism. If you also have astigmatism this could be the problem with the X100F. I have an XE-2 and it's VF is MUCH easier for me to see. I believe the XE-2 has a 23MM eye point compared to the 14MM of the XP-1? This makes a HUGE difference for someone with my glasses prescription. I believe the X100F has an eye point of ~15MM?
  7. khunfred61
    khunfred61 Premium Member
    Mar 7, 2014
    200
    62
    france
    Mmmm...X100F has a dioptric correction so I believe 99% of people with glasses can adapt to it. Maybe there is a 1% of people who can't but in that case they can't with any camera. Maybe the member evokes the 92% only coverage but when I need 100%, I switch to EVF.
  8. jmr
    jmr New Member
    Mar 31, 2011
    The West Riding, UK
    I wear glasses and I have an X100F and a Leica M.
    The eye relief on the Fuji is much better than the M. I've also tried the new M10, and although improved, it's still not as easy to see the framelines for the 35mm as it is on the Fuji.
  9. double00
    double00 Well-Known Member
    Mar 7, 2017
    39
    49
    Here is a comparison of Fujifilm cameras and their various viewfinder specs
    Camera Eyepoint (mm) EVF Size EVF Magnification
    X-Pro2 16 .48" .59x
    X-Pro1 14 .47" .6x
    X100T 15 .48" .65x
    X-T10 17.5 .39" .62x
    X-E2 23 .5" .64x
    X-T1 23 .5" .77
  10. jknights
    13,013
    2,812
    I think this is fair comment but I do wonder if the dioptre adjustment for the Fujis needs to be enlarged to +/- 5 diopters rather than the more limited +2 /-4 diopters in the X-T2, or +1 /-2 for the X100.
    I dont know what the X100F offers.
  11. khunfred61
    Mar 7, 2014
    200
    62
    france
    Same as X100.
  12. Alter Ego
    Alter Ego Premium Member
    Oct 28, 2012
    276
    44
    Edinburgh, UK
    I agree with the point made by the OP. I bought the X100F, having had the X100S, and having tried the X100T in Jessops. I found the viewfinder on both to be acceptable, whilst wearing my specs, and I assumed that the X100F would have a similar eyepoint. When I received it, it did not; something had been altered, even though the specifications are similar on paper. I therefore bought the X-Pro2, and it is better.
    Another post above also mentions adjusting the dioptre, and that the dioptres on both the X100F and the X-Pro2 are the same; they are not, as the X-Pro2 allows for a minus 4 to plus 2 adjustment, whilst the X100F allows minus 2 to plus 2. I can therefore use the X-Pro2 with or without my specs, and I prefer without, whereas I'd have to use the X100F with my specs, and lose some of the viewfinder.
    So, in my opinion, the OP is spot on! But, there are so many factors involved that it is not possible for a definitive statement to be made in relation to the experience, as some have sought to do, above.
    Charzes44 likes this.
  13. bophoto
    bophoto Premium Member
    Jul 13, 2013
    115
    46
    Oslo
    While it's true that the X100F has better eye relief and is a better finder in general compared to the X-Pro2, it's still nowhere near as comfortable to use and as easy to see "the entire picture" as with the X-T2/X-T1 viewfinder in "normal" mode for people using glasses, and specifically glasses that might stick a bit out from your face, or, if that person has deep eye sockets.
    Also, the X100F is usable with polarized sunglasses. You can still see the frame-lines and info overlay. The X-Pro2 doesn't work well with polarized sunglasses at all. The X-T2 and X-T1 uses OLED displays, so they are perfectly fine with polarized sunglasses.
  14. bophoto
    Jul 13, 2013
    115
    46
    Oslo
    That's got nothing to do with eyerelief. It's simply because the Leica M has a MUCH higher magnification ratio. Try looking through the Leica VF and X100F side-by-side. The world (or scene) is A LOT smaller in the X100F viewfinder than in the Leica. The Leica VF almost maintains real life size, whereas the X100F VF zooms things out (thus makes things smaller) by A LOT.
    This is what makes it more difficult to see the 35mm framelines on a Leica M, not the eye-relief.
  15. Solo with others
    Solo with others Premium Member
    Nov 28, 2014
    172
    182
    Dallas, TX
    Not all designs work for everyone. This one happens to work for me and not for you. Life is a buffet. Feel free to make your choices and try not to take away from the choices of others.
    CWRailman likes this.
  16. jmr
    jmr New Member
    Mar 31, 2011
    The West Riding, UK
    Thank you, you are of course correct.
    What I was trying to get across was simply that I find it easier to see the framelines with my glasses on using the X100F than I do with the M.
  17. dpt2014
    dpt2014 Dr. J
    Mar 29, 2013
    3,566
    793
    San Diego, CA
    Good thing no one is forcing you to buy the camera, eh?
    Not every camera is meant for every person for one reason or another. Life will go on.
  18. sccjim
    sccjim Member
    Jul 6, 2017
    I have the X100F, wear glasses and can see all of the viewfinder, both OVF and EVF.
  19. Jason P
    Jason P New Member
    Aug 10, 2011
    34
    Original X100 owner and glasses wearer - I've never ever had a problem with vignetting. It was for me one of the major attractions of the camera, being able to see 100% of the VF with my glasses on...
    Not being funny, but to the OP - have you ever checked that your glasses are the right distance from the eyes for you? Reason being I have a good friend who runs a spectacles business and he maintains many people have ill-fitting specs. Most high street opticians do not correctly adjust specs for optimal lens distance and arm length.
    Might be worth considering as there are many speccy X100 series owners who have no problem with the excellent VF on the camera. Seems a bit of a hollow criticism to throw at an excellent camera...
  20. RitchieReview
    RitchieReview Member
    Dec 15, 2012
    74
    Glasgow, Scotland.
    A couple of times it has been mentioned the x100f has a better viewfinder than the X Pro 2. Can anyone expand on that? Isn't the evf refresh rate supposed to be better on the Pro?
