Fuji X E3 skipping aperture stops
Discussion in 'X-E1, X-E2, X-E2S, X-E3' started by Rean, Dec 2, 2018.
  1. Rean
    Rean New Member
    Dec 2, 2018
    Hi,
    I have a Fuji x E3 with a 23mm f1.4 lens. The aperture changes consistently from f1.4 to f6.4 as I rotate the apature ring. But after f6.4 it goes to f7.1, stays there for a sec and immediately goes to auto apature(S or P depending on where the shutter dial is). And as I increase the aperture with the apature ring , f8 works and then it goes to f16, f14, f13, f14, f16 and then to auto.
    The apature setting is stuck in A+M in the settings(setup -> button/dial settings -> aperture setting )and cant seem to come out of it.
    I'm trying to figure out if there's any setting that's doing it or if the lens is faulty. Can someone please help me on this.
    Thank you
  2. Robmas4229
    Robmas4229 Premium Member
    Mar 13, 2015
    1,184
    840
    Florida, USA
    Have another lens to try? Otherwise try removing and remounting the lens? Cleaning the contacts?
  3. bralk
    bralk Premium Member
    Nov 30, 2016
    371
    549
    Denmark
    It´s probably related to this:
    I had the problem myself - fixed at Fuji Support UK
  4. Kirstybell
    Kirstybell Premium Member
    Oct 26, 2013
    1,167
    2,919
    I was going to suggest this, happened to my 35. Bummer!
  5. dincz
    dincz Premium Member
    Jun 5, 2016
    113
    173
    Brno, Czech Republic
    I've just returned a 60mm I bought on Ebay - same problem but at the f22 end. In aperture priority, it wouldn't go past f/16 without switching to P mode. Although I can't imagine using f/22 often, I'm concerned that the problem could get progressively worse and affect lower f numbers too.
    Having read of this seemingly common fault, I'm not sure I should keep looking for another.
    Thanks for the tip-off.
    PS - Is it likely that more recently manufactured examples have an improved and more reliable design? The one I bought had a 2012 serial number.
  6. bralk
    Nov 30, 2016
    371
    549
    Denmark
    That´s uncertain. I sold mine and got he 50/2.0 instead for a compact short tele. For macro I use a manual Nikon 55/2.8 macro lens with adaptor.
  7. Rosedalelad
    Rosedalelad Premium Member
    Mar 9, 2017
    138
    456
    Fuji optics are superb but modern production methods often don't allow a 'quality' construction. This is yet another reason to adapt legacy lenses.
    YogiMik likes this.
  8. YogiMik
    YogiMik Premium Member
    Sep 27, 2014
    3,675
    3,855
    Norway
    One of the reasons for me to not buy another electronic lens, anymore. Only mechanical ones.
    I'm fed up with the focus by wire, and a vision, that a lens can fail on me anytime without warning.
    Trouble, and extra expense to already expensive lens for the repair.
    Can't afford that.
    Rosedalelad likes this.
