Dropped Frames?
Discussion in 'Videography' started by (c)ow, Oct 5, 2018.
  1. (c)ow
    (c)ow Premium Member
    Apr 19, 2013
    1,481
    1,004
    Stuttgart, Germany
    pixelstate recently Please login or register to view links about stutter/lost frames. Now I have also two examples where, other than in his clip, I didn't do fast pans.
    Subtle but noticable.
    My setup/settings:
    -XH1 with XF16-55 mm lens
    - FHD, 25p, f-log
    - Battery grip, boost mode "on"
    - 1/50 s, ISO 800, f/5.6 (2), WB fixed
    - 2x SanDisk Extreme PRO 32 GB (SDHC II, 300 MB/s), sequential mode
    - IBIS on
    Any idea as to what's going on? In the post of pixelstate I asked already wether it's related with writing speed to the card. But in my case I have very fast cards.
    Thanks,
    Oli
  2. (c)ow
    Apr 19, 2013
    1,481
    1,004
    Stuttgart, Germany
    Nobody any idea??
  3. pszilard
    pszilard RemektekMedia.com
    Sep 14, 2011
    2,803
    945
    Sydney, Australia
    Check the floor under the camera. Might have dropped there... Just kidding. What memory cards are you using? Test their write speed, if you can.
  4. bralk
    bralk Premium Member
    Nov 30, 2016
    337
    499
    Denmark
    IBIS?
    I had the same problem with a Panasonic video cam with ibis active
  5. (c)ow
    Apr 19, 2013
    1,481
    1,004
    Stuttgart, Germany
    That would be a bummer. IBIS should be beneficial for handheld video shots...
    Ah, one more thing: my XT20 did it also, no IBIS.
    When I return home from BKK I‘ll check the speed of my SD cards. The Blackmagic tool should do
  6. (c)ow
    Apr 19, 2013
    1,481
    1,004
    Stuttgart, Germany
    Did a speed test with two different tools: Blackmagicdesign Disk Speed Test and HELIOS LanTest. I used a Lexar highspeed SD card connector for UHS II -> USB 3, because my internal card reader is far slower. Here are the results for 3 different cards:
    What does this test tell? Obviously I used the fasted card for video recording. But is write speed really the problem? Are there faster cards out there (that work proper with the XH1)?
  7. Greybeard Photography
    Apr 23, 2017
    511
    146
    Just checked the Fuji site and it seems that the X-H1 is only operating at 50Mbps for FHD 25p so its unlikely to be the card - even the Sony card should be able to manage that.
    Do those speed test programs show minimum write speed or is that average?
    I have wondered about this with reference to the X-T3 and 400Mbps. Does the video stream bypass the buffer? I've never seen anything on this subject.
  8. (c)ow
    Apr 19, 2013
    1,481
    1,004
    Stuttgart, Germany
    The HELIOS app does 10x write/read operations and averages the result. From the BM app I just read the value.
    The sample videos were shot with these settings:
    1080p, 25 FPS, F-log, 100 MB/s
    The 100 MB/s recording speed is below the measured write speed of the SanDisk card, which I've used for the above videos. Still I don't understand this phenomenon.
