Dent in battery
Discussion in 'Fuji X Accessories' started by AndresC, Oct 11, 2018.
  1. AndresC
    AndresC Premium Member
    Dec 11, 2017
    500
    996
    Panama
    Hey guys, just noticed that there is a dent in my oem fuji battery and I’m wondering if this is something that I should be worried about.
  2. Arjay
    13,639
    5,455
    You mean the cutout at the bottom left in your photo?
    If yes, that's perfectly normal: That's a design feature of this battery which makes it impossible to insert the battery into the camera the wrong way around.
  3. AndresC
    Dec 11, 2017
    500
    996
    Panama
    Sorry should have marked it, it’s just over the circle with the letters PSE in it.
  4. streetsntravel
    1,207
    757
    If the battery is returnable, I would do that just for safety. Mechanical damage to lithium batteries can compress the inner layers of Li/foil and that can lead to an internal short. Generally these take a lot of routine handling and normally hold up to dropping. An obvious compression is IMO problematic.
    kevistopheles likes this.
  5. AndresC
    Dec 11, 2017
    500
    996
    Panama
    I was afraid of this type of answer, it’s not returnable at all as I’ve had the camera for almost a year now. I don’t remember dropping it, but there’s two small girls in the house and I left it at arms reach which is my mistake!
  6. Shadowside
    Jun 24, 2013
    2,365
    2,273
    Winnipeg, Canada
    Trash it. Unless you think it's worth your camera or worse.
    Lithium batteries are cheap compared to the damage they can do when they fail.
    James King and kevistopheles like this.
  7. kevistopheles
    kevistopheles Premium Member
    Oct 21, 2014
    3,501
    4,881
    I’d ditch it. There are some decent third party batteries out there that are much cheaper than OEM but still good. I’ve used Red Dot, Watson and Wasabi.
    They don’t last quite as long as the Fuji but still useful.
    Shadowside likes this.
  8. AndresC
    Dec 11, 2017
    500
    996
    Panama
    You guys make valid points, just wanted to be sure as the oem had much better life than the wasabis I’ve got. I think I’ll order a Watson and try that out.
  9. CriticalMass
    CriticalMass Member
    Jun 19, 2018
    28
    I’m with the consensus here. Ditch it.
  10. Lieven Lema
    Lieven Lema Premium Member
    Dec 3, 2013
    679
    332
    Brussels
    IMO Patona is better, Wasabi is indeed low quality.
    JimFenner and Dirk Offringa like this.
  11. ChooChooTrain
    ChooChooTrain Member
    May 25, 2018
    19
    Hard to tell from the photo, but it may just be a manufacturing defect in the plastic casing. I would keep using it. Lithium batteries usually swell (from hydrogen gas build up) before they blow up. It's the swollen batteries that you need to watch out for.
  12. FujiMongol
    FujiMongol Premium Member
    Oct 13, 2017
    390
    217
    If the chemical layers are not affected by the dent then you're fine.
    If they are affected you're taking chances.
    So here is a little gamble.
