constant or favourite exposure compentation
Discussion in 'General X Camera Forum' started by Dwiputraltf, Feb 8, 2018.
  1. Dwiputraltf
    Dwiputraltf New Member
    Jan 15, 2018
    38
    halo can you guys tell me which constant/favourite exposure conpentation?for refference,especially for shooting people
  2. bralk
    bralk Premium Member
    Nov 30, 2016
    187
    325
    Denmark
    + 2/3 for RAW
  3. FORUM USER
    FORUM USER Member
    Feb 7, 2018
    45
    Favourite on odd number days and months with an r in them is +1
    MickM likes this.
  4. ruby.monkey
    ruby.monkey Premium Member
    Mar 23, 2015
    430
    256
    England
    None. I prefer manual control with exposure preview in the viewfinder.
    oddasea likes this.
  5. MickM
    MickM New Member
    Dec 9, 2017
    . . . and presumably between the hours of 0730 and 1545 . . .
  6. FORUM USER
    FORUM USER Member
    Feb 7, 2018
    45
    Exactly.
    I'm very lucky that Fuji included my favourite exposure compensation number on the top plate selector dial.
    SoulDog likes this.
  7. gyoung
    gyoung Premium Member
    Oct 3, 2013
    430
    136
    Nottingham
    I'm not sure if I should be serious for a moment. ..
    ....but +1 or +.66 is very useful for backlit shots or bright skies.
    Gerry
  8. streetsntravel
    956
    534
    If by chance your camera was set at factory defaults when new, then my first choice would be zero compensation.
    If you shoot exclusively RAW, I would tend to leave it on zero and then adjust only as the situation requires.
    If you shoot exclusively JPG, then you may or may not have some picture controls set (i.e. shadow and highlight offsets) that may or may not tempt you to set a "permanent" exposure offset.
    If you shoot portraits and your subjects tend to have a light skin or a dark skin, then you may want to have an exposure routine that involves exposure compensation to produce what you want.
    As already mentioned, backlighting may also figure into your exposure calculations and possibly compensation.
    ..... and so it goes ....
    Back to that factory default and the Fuji control set presentation that tempts so many people to join the system, just because there is a dial, it doesn't need to be changed.
  9. Dirk Offringa
    953
    537
    There isn't any. It's a parameter you might need, every once in a while, for some particular conditions, when one of the three base measuring modes (spot, centre-weight, average) do not produce a satisfactory result, and you don't want to bother with AE-L. Or to balance ambiant and flash. If you don't need it, then don't use it.
  10. Arjay
    13,373
    5,119
    I agree with all the serious comments that were made above.
    It may be worth pointing out that permanent exposure compensation settings are a thing that harks back to the age of film photography, when practically no film would provide its very best results or a desired look at its rated ISO/ASA value. Depending on the development process, the employed development solutions or other desired characteristics, users had to apply permanent EC factors.
    Today, the only variables are whether you shoot JPGs only, or have specific personal preferences for a desired look. Besides that, a good understanding of your camera's exposure metering modes should in most cases make permanently using an EC factor superfluous.
  11. Otohp70
    Otohp70 Premium Member
    158
    29
    Oregon
    Don’t use it.
    One thing I do like about the layout on the new XH1.
    Otohp.
    lysander likes this.
  12. FMW
    FMW Premium Member
    May 11, 2017
    264
    118
    The use of exposure comp. depends on the light. There is no universal right or wrong. Only right or wrong for a given lighting situation. I never used it in my DSLR days because it required menu work. The dial on the Fujis makes it easy to use and I do use it now.
  13. ChiDN
    ChiDN Fujiholic Cub Fan
    Aug 2, 2013
    1,210
    632
    Chicago, IL
    +1
    Like Arjay said so use the dial according to taste. When shooting RAW I often ETTR and get that ETTR by using the compensation dial. Shooting JPGs = to taste.
  14. rlx
    rlx Premium Member
    Jun 22, 2013
    175
    44
    Montreal
    I would like to have none of the skin overexposed (other than specular reflections) so I can adjust the tones in PP if needed. There are so many compositions with all kinds of lighting so there is no fixed setting of EC for me. The EC control is the one I use the most often on my camera; I wonder how I would manage with the XH1; I would use the AE-lock button instead I guess.
