Can't enable hybrid OVF
Discussion in 'X-Pro2 and X-Pro1' started by pszilard, May 15, 2018.
  1. pszilard
    pszilard RemektekMedia.com
    Sep 14, 2011
    2,843
    960
    Sydney, Australia
    Took my X-PRO2 off the For Sale list and went through the menus, setting up things. However, somehow I have disabled the Hybrid OVF mode! Flicking the front lever towards the lens, when in OVF mode, no longer activates the little hybrid LCD insert!
    Can't find any way that I could have turned off this mode, or how to reset. Any recommendations? (Might try a factory rest...)
  2. Just Browsing
    Just Browsing Member
    May 7, 2018
    69
    Have you tried flicking the lever away from the lens when in OVF mode?
  3. pszilard
    Sep 14, 2011
    2,843
    960
    Sydney, Australia
    That just toggles OVF/EVF
  4. Just Browsing
    May 7, 2018
    69
    Yes, sorry, should have said in same direction again.
    Select OVF and then push again - in same direction.
  5. pszilard
    Sep 14, 2011
    2,843
    960
    Sydney, Australia
    Didn't I state that it didn't work in my first post? That is why I am asking for help.
  6. Just Browsing
    May 7, 2018
    69
    Yes I guess you did state. Only trying to help. Have you tried shoving it?
    LionSpeed and CSG like this.
  7. specLegacy
    specLegacy Premium Member
    Jun 4, 2013
    674
    241
    Houston
    The ERF isn't available in Zone or Wide AF modes, only single point AF. Is that the issue?
    patio and pszilard like this.
  8. JimFenner
    JimFenner Premium Member
    Aug 3, 2014
    392
    158
    Canberra
    I reset my X-Pro2 to fix that problem. Not that I use the ERF.
  9. pszilard
    Sep 14, 2011
    2,843
    960
    Sydney, Australia
    You are a LEGEND! That was it. Many thanks. I owe you a beer. :)
    specLegacy likes this.
  10. specLegacy
    Jun 4, 2013
    674
    241
    Houston
    Glad to help!
  11. patio
    patio Well-Known Member
    Jan 6, 2016
    93
    Man, that's the one problem with these cameras and i've been using the Xpro system since 2015. They're very confusing and packed with almost too many features.
