Bright nightshift
Discussion in 'General' started by Demoz, Feb 11, 2018.
  1. Demoz
    Demoz Premium Member
    Mar 19, 2013
    505
    675
    mozambique
    X-Pro2, Nokton 35 f1.2, Revuenon 55 f1.2
    Reconditioning of an excavator bucket. Removing worn plates, fixing cracks, welding new wear plates on.
    Gouging:
    Grinding:
    Welding:
    Thanks for looking.
  2. Illumidata
    Illumidata Premium Member
    Nov 2, 2014
    364
    847
    United Kingdom
    These sets are beyond awesome. The lighting you've been getting is just superb!
    Demoz likes this.
  3. Nick.k
    Nick.k Premium Member
    Nov 26, 2017
    167
    281
    Well done! You've really captured the feel of this type of work with the light, smoke, sparks and dust. I like the texture of the plates in the foreground of the first with the cooling globs of metal still glowing.
    How are you protecting your camera? The feel here is from being right up close, I like it.
  4. Mk1
    Mk1 Premium Member
    Oct 22, 2011
    477
    244
    Bucks UK
    Great stuff love the light capture and exposure nice set!
  5. Demoz
    Mar 19, 2013
    505
    675
    mozambique
    Thank you very much for the positive feedback and the likes.
    Thank you. Gouging is even brighter than welding, resulting in extremely high contrast. I have pulled up the shadows a bit on all 3 of them.
    Thank you. I got a bit worried, when I felt grinder sparks raining on my head, I am not using any filters, so I could have damaged the lens coating quite easily with a hot spark. Fortunately no damage done...
    Thank you. I have a few more shots of this engineering shop. Whilst I shot there, one of the welders said to his colleague "I know, what this man is up to. He will make a calendar for this company.." I think he had a great idea there, A2 would do just fine I guess....
    Illumidata likes this.
  6. AdrianG
    AdrianG Premium Member
    Feb 22, 2016
    1,549
    1,221
    CH, UK, GHA
    No hardfacing, interesting. Digging in soft soil?
  7. Demoz
    Mar 19, 2013
    505
    675
    mozambique
    They are loading coal in the nearby mine. Not sure, what steel they use for the wear plates and if there is any coating. If I am not mistaken, they cut the wear plates locally on a plasma cutter.
  8. AdrianG
    Feb 22, 2016
    1,549
    1,221
    CH, UK, GHA
    The plates are probably Hardox or something the like, but the front edge and the teeth are often hard surfaced. But then, sometimes it's cheaper to use plain steel and get a new bucket every now and then. Using the expensive stuff pays if you have well trained female drivers only.
  9. Demoz
    Mar 19, 2013
    505
    675
    mozambique
    The buckets and bins are being re-conditioned periodically. The wear strips are supposed to wear rather than the structure of the bucket or bin. Once worn to a certain measurement they get gouged out and replaced. There are different types of bucket tips available, depending on the application of the machine.
    I do not quite get the relevance of the operators gender. I thought the latest wisdom was, that all 50 odd genders are equal and the same...
  10. leoda1945
    leoda1945 Premium Member
    Apr 30, 2013
    1,255
    1,099
    People's Rep. of Mass.
  11. AdrianG
    Feb 22, 2016
    1,549
    1,221
    CH, UK, GHA
    I only know of 2 genders and while they should be treated equally and given equal opportunities they are most certainly not the same. Just like women are a lot more likely to give birth to children than men, they are a lot less likely to damage heavy equipment than us whilst beeing a little more productive at the same time. That's a well known and well documented fact. Having all female drivers roughly means you need 8 istead of 10 loaders due to less down time and extended service life.
    Anyway, hard surfacing looks like this:
    There's not a whole lot of detail, because I took this OOC JPEG with the XP2 at 12800 ASA. You're looking down into a 3m diameter breaker-mixer feeder. This is heavy clay works machinery, it is one of many steps in clay conditioning for brick and/or tiles production. This particular machine is in Brasil. The upper two arms were removed for rebuilding and hard facing, the bottom one remained in the machine. That's why the hard facing seams are 5 to 7cm wide on the upper arms while they are only about 1 to 2cm on the bottom one. This hard facing was welded with endless 2mm cored wire @around 350A.
    Demoz likes this.
  12. Demoz
    Mar 19, 2013
    505
    675
    mozambique
    Was that shot taken before removing and rebuilding the upper arms? At the size and ISO, I find the level of detail impressive. Clay tends to force its way into any opening and then hydraulics your equipment to bits.
    We had female tractor operators on a GPS levelling operation in a sugar estate on 375 - 450hp articulated tractors. It was a positive experience.
  13. AdrianG
    Feb 22, 2016
    1,549
    1,221
    CH, UK, GHA
    That was after the machine had been reassembled and adjusted, the weld spatter ground off the bottom wear plates, tools, welding gear, smoke suction, respiratory equipment, etc cleared and the machine had done a few revolutions by hand to make sure nothing touches the bottom or sides. After a few hours of use or before disassembly all surfaces are polished by the clay and shine like mirrors.
