Best way to handle your X100 series Camera
Discussion in 'X100F, X100T, X100S, X100, X70, XF10' started by kivis, Sep 16, 2018.
  1. Grip
    10 vote(s)
    17.5%
  2. Thumbs up
    18 vote(s)
    31.6%
  3. Half Case
    17 vote(s)
    29.8%
  4. Nothing
    19 vote(s)
    33.3%
Multiple votes are allowed.
  1. FrankBB
    FrankBB Premium Member
    Feb 6, 2013
    875
    1,549
    San Diego, California
    I wonder what sort of heat build up you would get with a silicone case like that? I know that these camera do heat up at times; at least, mine do.
  2. Frankie
    Frankie Premium Member
    Mar 31, 2011
    3,619
    672
    The Left Coast
    Silicone in general is known to withstand even oven heat up to 400+ degrees F. I'm sure the case won't melt under any camera heat up.
    As to whether silicone insulates the camera more retarding heat dissipation...I don't know.
  3. wsavitz
    wsavitz Member
    Apr 6, 2013
    27
    Ohio
    I would bet that it does.
  4. lbe
    lbe Member
    May 18, 2014
    30
    norway
    Been shooting width the x100s since 2013. Never missed anything. Keeping it simple
  5. Topsy
    Topsy Premium Member
    Dec 2, 2012
    2,333
    1,306
    Devon, UK
    I used the Lensmate Thumb Grip on my X100T and found it just the job. Had similar on my X-Pro1s and now use Thumbs Ups on my Leica M9s. I think they give just enough additional grip without getting over bulky. BTW I never use flash, if you do the thumb grips need to come off for it so I imagine becomes awkward if not PITA.
    Musicophile likes this.
  6. sccjim
    sccjim Member
    Jul 6, 2017
    Another vote for the Lensmate Thumb grip. Allows me to use the camera with one hand when I want to. It should be on the camera right from the factory. It makes that much of a difference. I'm also using the one from my T.
  7. Mk1
    Mk1 Premium Member
    Oct 22, 2011
    698
    535
    Bucks UK
    I love the lensmate thumb grip it’s on my X100T with the original Fuji grip and together they work very well
  8. cug
    cug Premium Member
    Oct 9, 2013
    3,200
    1,172
    California
    I use exactly the same combination, just on an all black camera – makes the Flutschi much easier to handle ... ;-)
    There are a few things I don't like about the setup:
    1. The thumb grip gets in the way of the rear control wheel which is actually used for quite a lot of functions on the X100F.
    2. The front grip is kind of heavy for such a small camera.
    3. I have to pull the thumb grip off whenever I use a flash (the internal doesn't work with the lens hood I have and it also doesn't work with the TCL, so I always carry an EF-X20 small flash with me.
    #3 is actually my biggest gripe as handling is now different when the flash is on, which is even more annoying than #1.
  9. kivis
    kivis Premium Member
    Oct 24, 2013
    271
    53
    Southern, Florida USA
    Pimped X100f
  10. Ish
    Ish Premium Member
    Feb 5, 2013
    2,561
    594
    Northamptonshire, UK
    It's better to keep it as an add on for those that need it. I handled one a little while ago which had a thumb grip and my thumb didn't even reach that far!
