A FABULOUS Macro Conversion Lens
Discussion in 'Fuji X Accessories' started by Dick Quinn, Jun 15, 2013.
  1. Grippa
    Grippa Active Member
    May 23, 2016
    142
    27
    Tasmania - Australia
    I removed the Fuji thread protector ring but this exposes a male thread, unusual for this industry. Actually I had forgotten what was on there because I removed it on the first day and installed a protective glass over the movable focus mechanism. I am travelling and the original trim is at home in the box. I looked at the Filter Adapter Ring on eBay and that is what I require. I don't want to order the Raynox lens until I know it will fit. And yes I will get the step down ring as well to make a better job of it.
    Thank you for your assistance Jamie, you have been most helpful.
    If anyone is interested in this conversation, the X100T makes an excellent lightweight hiking camera, with a very suitable focal length for landscapes. The Raynox lens will be for macro when hiking as I've found I am getting too much dust into my X-T1 changing lenses and extension tubes. Another great use for this superb little camera!
  2. jamie allan
    jamie allan Premium Member
    Aug 2, 2014
    1,411
    1,656
    Glasgow Scotland
    Grippa,
    If you look at the calculator on the extreme macro site you can calculate the magnification factor for the X100T 23mm lens. According to the Fuji site specs for the X100T 23mm the magnification factor is 0.25 on it's own. With the Raynox 250 you'll get 0.48:1. I use mine on a Fuji X-T1 with 50-230mm lens. At 230mm the magnification is 2.4:1 and the working distance is about 110-120mm. I've seen a comment that the Raynox was designed for focal lengths from 100-300mm.
  3. jknights
    12,502
    2,563
    Nice work Carolyn.
    How much do I need to save up?
  4. Grippa
    May 23, 2016
    142
    27
    I've got the Fuji extension rings for my XF 50-140mm but this is all too heavy on three day walks, and in unsuitable environments to be changing lenses. I don't understand magnification factors, can you tell me in layman's terms, if I buy a Raynox for the X100T, will the object fill more of the screen? and how close do I have to be?
  5. jamie allan
    Aug 2, 2014
    1,411
    1,656
    Glasgow Scotland
    Grippa,
    Here's another calculator from the extreme macro site that lets you calculate magnification and working distance.
    To find the requisite information from Fuji
    So the standard lens without WCL or TCL has a shooting magnification factor of 0.25 (or 1:4) with a minimum focus distance of 100mm(10cm). Therefore the Raynox increases the magnification to 0.48:1 ie just less than half size. This is almost double the magnification of the lens on it's own. The working distance appears to be 5.56 to 12.5cm.
  6. Grippa
    May 23, 2016
    142
    27
    Thank you Jamie, I really appreciate your help, I've also found some examples online. It may not be the best way to shoot macro, but it may be the best for hiking with equipment.
